product template problem
12 years 3 months ago #167911 by christofu
-- HikaMarket version -- : 1.4.3
-- Joomla version -- : 3.3.3
I have used the product template to force some values for certain fields. when I dont use the template my product code is automatically generated from the title, and it seems the product URL is generated from the Alias?
when I do use the product template the URL appears to come from the name of the Template (rather than the product name) and the code is equal to the code that is automatically generated for the Template e.g. @template-53c5bb2e6c4b8 - which it tries to duplicate every time you add a product.
Is this expected behaviour for the Template?
12 years 3 months ago - 12 years 3 months ago #167917 by Jerome
Replied by Jerome on topic product template problem
Thanks for the report.
You're right, it's an unexpected behaviour of the product template system.
I will fix and update the HikaMarket package as soon as possible.
You can edit the file "administrator/components/com_hikamarket/classes/product.php" and replace
$template = $this->getRaw($template_id, true); foreach($template as $k => $v) { if(!isset($product->$k)) $product->$k = $v; }
By
$template = $this->getRaw($template_id, true); foreach($template as $k => $v) { if(!in_array($k, array('product_code')) && !isset($product->$k)) $product->$k = $v; }
It will exclude the "product_code" from the product template while creating a new product.
Last edit: 12 years 3 months ago by Jerome. Reason: code fix
12 years 3 months ago #167934 by christofu
Replied by christofu on topic product template problem
thanks, I replaced that and received this error when I tried to add a new template:
Parse error: syntax error, unexpected '$product' (T_VARIABLE) in /home/siftmrkt/public_html/administrator/components/com_hikamarket/classes/product.php on line 320
12 years 3 months ago #167935 by christofu
in fact the error occurs on every page - so I rolled it back to the original code for now
12 years 3 months ago #167960 by Jerome
I fixed the code in my previous post.
12 years 3 months ago #168299 by christofu
Hi Jerome,
yes that worked for the code - brilliant:)
I noticed the Alias also automatically defaults to a variation of the template name - is that able to dynamically change to a variation of the new product name instead? (which will automatically change based on duplicate product names so it doesnt have to be exact)
12 years 3 months ago #168304 by Jerome
Well, we can also include the product_alias in the list of exclusion.
if(!in_array($k, array('product_code', 'product_alias')) && !isset($product->$k))
12 years 3 months ago #168371 by christofu
hmm just recieved a general error after adding that one:
"An error occured while saving the product"
tried adding a new Template with the same error
12 years 3 months ago #168383 by Jerome
It means that I should make some tests in order to understand what happened (because like that, I can't say).
The best will be to revert the latest modification in order to keep the "product_alias", so you will be able to save items correctly.
12 years 2 months ago #170203 by christofu
Hi Jerome I added the code you suggested (for alias) underneath:
else
$vendor->alias = JFilterOutput::stringURLSafe(strip_tags($vendor->alias));
I am not sure if this is correct?
result is there is no error but there is no change in the alias behaviour. Every product assumes the alias (and hence page URL) of the product template, resulting in every created product pointing towards only 1 product. I have the program set to automatically generate the alias from product name, so it seems with a template it automatically generates the alias from the template name instead!
When I dont have a Template it generates the alias correctly
I am just using the template to set certain values when somebody adds a product
thanks
12 years 2 months ago #170253 by Jerome
Can you tell me more about the "program" which automatically generate the alias ?
Because the patch I gave you in this thread should work ; I don't understand your problem and as you know, I can't reproduce it.
12 years 2 months ago #170352 by christofu
in Hikashop / Config / features / SEF url options you can set Alias to be filled automatically. This is working fine.
Its just when I use the Product Template any product I create takes on the alias of the product Template name
The code you gave me above might fix it, I was just unsure where to place it (that is certainly not my strong point) - if you could help me regarding the placement that would be great:)
thanks
12 years 2 months ago #170362 by Jerome
The code I gave you will fix it.
But I though you already used it...
In my first reply in this thread, I gave you 4 lines to replace ; and in the next reply, I gave you one line to change in the previous 4 lines.
I did not specified the replacement because it was from the previous message (like I wrote in that message).
So please, use the modification.
The following user(s) said Thank You: christofu
12 years 2 months ago #170512 by christofu
Thanks Jerome,
not my strong point so your last comment cleared up what do with the code & it works! I presume you will update in the next version so I dont need to create an override file?
thanks again for your help :lol:
12 years 2 months ago #170513 by Jerome
Yes, the code is already committed for the next release.
12 years 2 months ago #172724 by christofu
I had to upgrade to the newest version of Hikamarket to resolve some other problems - in doing so I have had some issues pop up with my product template file resulting in either:
1. the product assumes the name of the product template (instead of its own name)
or
2. the product assumes the correct name but there is a 404 error
I have removed the product template to test adding a product without and it has the same results
I have checked the code above is in the updated edition and it is (though I had to add the product alias addition)
is this a familiar error?
12 years 2 months ago #172725 by Jerome
We are building a new version which should be release tomorrow.
12 years 1 month ago #173043 by christofu
Hi Jerome,
is the 1.4.4 that is available now the latest version?
I have tried updating and I am still getting some familiar errors...
thanks
12 years 1 month ago #173065 by Jerome
The exact same problems than in your previous post ?
I tried to reproduce it but I couldn't. I think I don't have the same "product template" configuration than yours.
12 years 1 month ago #173104 by christofu
yes its the same problem - i.e. the same error at the top of page when you add a new product "Warning: Creating default object from empty value in /home/siftmrkt/public_html/components/com_hikamarket/views/productmarket/view.html.php on line 487"
I had removed the product template altogether to test first, and I have these problems:
  • add product form has error at the top (as per my above images) but it saves the product
  • when you access the product it brings up a 404 error
so perhaps the product template is ok, but it is something else?
the error started when I updated to the latest 1.4.3, and still exists when I updated to 1.4.4 today
Time to create page: 0.128 seconds
