Vendor Control Panel Statistics Not Showing
11 years 4 months ago #206506 by DeeEmm
-- HikaMarket version -- : 1.6.3
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.3.10
-- Browser(s) name and version -- : Dave
The statistics in the vendor control panel are not showing.
This could possibly be due to an overridden template file as I modified many of the template views when originally setting up the site.
I have enabled the stats in the settings but cannot see them in the front end.
I have checked in views/hikamarket/vendormarket/cpanel but this is the same as the version found on the server.
What template view file is responsible for showing the stats?
DM
11 years 4 months ago #206529 by Jerome
The stats are displayed in the view "vendormarket | cpanel" but are related to HikaMarket ACL.
So you first need to be sure that your vendors have the ACL to display the statistics : vendor/statistics
The following user(s) said Thank You: DeeEmm
11 years 4 months ago #206637 by DeeEmm
That was it!
Not enabled in the ACL
Thanks Jerome.
