Hikashop/Hikamarket ... adding products from front
11 years 2 months ago #214293
by QureshiMo
Hikashop/Hikamarket ... adding products from front was created by QureshiMo
-- HikaMarket version -- : 1.6.5
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.5.12
Hello:
How can I set up a user who can add products?
So far ...
(1) I have installed HikaMarket with Hikashop Business Edition.
(2) Created a user and using HikaMarket given access to product
By the way: I already created a menu for Displaying Orders using Hikashop "Customer Order" type.
Now, I need to create a menu when click should take the user to add product page.
Thanks,
<<< Ali >>>
Hello:
So far ...
Thanks,
<<< Ali >>>
11 years 2 months ago #214295
by Jerome
Replied by Jerome on topic Hikashop/Hikamarket ... adding products from front
You should be able to create a Joomla menu to directly create a new product.
Like : pasteboard.co/Fb2m8rL.png
Regarding your access configuration, if the user is in the group "shop_orders" he will have access to the product edition.
But you have also to add the user in the authorized users in your HikaMarket configuration (under "your vendor" tab).
11 years 2 months ago #214324
by QureshiMo
Replied by QureshiMo on topic Hikashop/Hikamarket ... adding products from front
Thank you ... I got it working(Well almost).
For the menu option, when I click Hikamarket Option tab, the Hikamarket option is displayed which is clickable.
When I click on the Hikamarket option, something flashes on the screen (Looks like the information from the detail tab). then nothing is displayed.
Should there be options listed when I click Hikamarket option?
Thanks,
<<< Ali >>>
Thanks,
<<< Ali >>>
11 years 2 months ago #214364
by Jerome
There is no HikaMarket options for this kind of menu ; I'll see to remove these links for the next release.
Since HikaMarket 1.6.5, the module and menu settings are directly in the Joomla 3 interface, when the old configuration system is still available for Joomla 1.5/2.5.
11 years 2 months ago #214579
by QureshiMo
11 years 2 months ago #214613
by Jerome
In the view "ordermarket | listing", there is the conditional code:
before displaying the biliing address ; so I suppose that the ACL might be set directly in the user settings.
I performed a test and I removed directly the "order / show / billingaddress" right to one account and the billing address is not displayed anymore. So I think it is related to the user ACL configuration.
About the order status, you have to go in the order details in order to change the order status.
There is no feature to change the order status directly in the order listing ; it is something we are thinking about but for the moment that is not available.
if(hikamarket::acl('order/show/billingaddress') && !empty($order->order_billing_address_id)) {
