Associated product : Product of the same vendor
11 years 1 week ago #218817
by newt
Associated product : Product of the same vendor was created by newt
-- url of the page with the problem -- : solishop.fr
-- HikaMarket version -- : 1.6.5
Hello !
Under the product there is a associated product module.
I want to know how can I only display the product of the same vendor ? Is it possible ?
Hello !
11 years 1 week ago #218819
by Jerome
Replied by Jerome on topic Associated product : Product of the same vendor
Yes ; thanks to the plugin "hikashop / productfiltervendor" provided by HikaMarket.
That plugin requires ID of HikaShop product listing modules and it will modify the SQL of that modules to add a filter on the vendor depending the displayed page. The goal for that plugin is to filter on the vendor you're viewing or on the vendor of the current displayed product.
The following user(s) said Thank You: newt
11 years 1 week ago - 11 years 1 week ago #218940
by newt
Replied by newt on topic Associated product : Product of the same vendor
I found the plugin but I don't find the Hikashop product listing module.
I juste have to put its ID ?
Last edit: 11 years 1 week ago by newt.
11 years 1 week ago #218958
by Jerome
My bad ; the plugin "productfiltervendor" does not have the good goal for your requirement.
The best is to create a new setting for the HikaShop product listing modules allowing HikaMarket to generate the vendor filter.
HikaMarket already add some settings in product listing modules, like "show sold by".
Please use the "contact us" form, with some indication for the HikaMarket license and we will send you a patched file for the plugin "hikashop / market" which will add that new setting.
That new setting will also be include in the next HikaMarket release.
11 years 1 week ago #219144
by newt
Where can I find the 'contact us" form ? On joomla ?
When will be release the next Hikamarket update ?
11 years 6 days ago #219150
by Jerome
For the moment there is no planned date for the next HikaMarket release but I think it will be during this month.
I still have one (minor) bug in my TODO list ; once close I would be ready.
11 years 6 days ago #219238
by newt
Ok
Thank you very much ! I'll wait then
