- Thank you received: 2
Products of different vendors in cart
9 years 10 months ago #260130
by woidl
Products of different vendors in cart was created by woidl
I want my vendors to be paid directly by the customers.
I have different vendors, different warehouses, different products...
So I activated in Hikamarket "Limit vendors in cart = One vendor".
But this did not help - I can still put several products from different vendors into my cart. No limitation, no error message.
Maybe I missed something,
thanks for your help
9 years 10 months ago #260134
by Jerome
Replied by Jerome on topic Products of different vendors in cart
Because it was your first post in the forum, your message needed an approval.
The unwanted side effect is that the information you gave about your website and the version number has been lost (I hope that we will be able to fix that issue soon).
So, can you please gave us the version number of HikaShop and HikaMarket you're using ?
9 years 10 months ago #260180
by woidl
Replied by woidl on topic Products of different vendors in cart
Versions:
Hikashop: 3.0.0
Hikamarket: 1.7.2
thanks
Walter
Versions:
Hikashop: 3.0.0
Hikamarket: 1.7.2
thanks
Walter
9 years 10 months ago #260190
by Jerome
Can you please re-download HikaShop 3 in order to be sure that you have the latest version ?
I checked the legacy triggers for the new HikaShop cart system this month and I was able to retrieve the cart limitation system with a little patch in the HikaShop core.
I wanted to be sure that no patch in HikaMarket would be require in order to support HikaShop 3 and, for what I tested with latest build, it was fine. So if with that latest build you still have an issue, we will need to reproduce your problem in our side (and have some details about your current configuration to duplicate it).
Reards,
Reards,
9 years 10 months ago #260278
by woidl
with the latest 3.0.0 - it works now: products of different vendors are not allowed in cart.
thank you, Jerome
thank you, Jerome
