- Thank you received: 19
Prebuilt products
9 years 7 months ago - 9 years 7 months ago #265340
by neo191987
Prebuilt products was created by neo191987
Hi I want to do the following: a partner to be able only to set price and attached packages of hikaserial in already prebuilt products from me. In testing these products are created are not visible to other partners. Can these products be available to other partners (to have the opportunity to create a variant of the product with their prices and packages based on this product that I created).
I also want to ask is it possible list of vendors seem similarly.
Last edit: 9 years 7 months ago by neo191987.
9 years 7 months ago #265351
by Jerome
Replied by Jerome on topic Prebuilt products
In your main product, if you add the characteristic called "vendor", then your vendor will be able to create their own variant.
For the moment, they have to go in the product page and they will see a button to "edit/create" their variant for the product.
Afterwards, in HikaShop you can change how the variant selection is made ; one mode is using a table.
Thanks to some view override ; you can change the way that the product are listing and add special columns.
With some code, you can load the vendors' detail of the different variants and include that data in your table.
It requires some development skills and some time ; but that is possible.
9 years 7 months ago #265354
by demo
Replied by demo on topic Prebuilt products
Thanks for the reply. By selecting this characteristic requires value what should be accurate.
And also I want to ask what the user group must be a vendor if there is any significance.
Attachment not found
9 years 7 months ago #265400
by Jerome
Thank you for the report.
There is indeed a problem with the new product edition interface and the "vendor" characteristic.
The code which is in HikaMarket still work for the "legacy" product edition but not for the new one ; I didn't realized that.
We are currently working on some modification in HikaMarket but it will also require some modifications in HikaShop (to potentially add a new trigger)
The "vendor groups" are just there to simply the Access Level configuration ; so you can activate or block some Access Level depending the groups that a vendor have.And also I want to ask what the user group must be a vendor if there is any significance.
The following user(s) said Thank You: neo191987
9 years 7 months ago - 9 years 7 months ago #265416
by neo191987
Replied by neo191987 on topic Prebuilt products
I found some small problem but will not open new topic will only report in order to correct them in the next version.
Front end
There are two problem page Customers
1, Missing the two strings: HIKAM_NO_ADDRESS and NO_ORDER_LISTED
2. drop down list to the address generated this <em>HIKAM_NO_ADDRESS</em> instead HIKAM_NO_ADDRESS
I corrected those problems to me.
Page Products
When creating a product - Auction fields are not available for operation.
Also can not be excluded from the administration.
Page Discounts
When creating a discount if you click on the button Specific vendor show two popup windows instead of one.
Front end
Page Products
Page Discounts
9 years 7 months ago #265426
by Jerome
1 - It will be fix in the next release
2 - It will also be fix in the next release
3 - Please provide more details or open a new thread ; it might be related to HikaMarket but only to HikaAuction.
4 - We will perform some tests in order to reproduce the issue ; please indicate the browser you're using.
9 years 7 months ago - 9 years 7 months ago #265462
by neo191987
4.Testing of the Google Chrome and Mozilla Firefox – Last versions
Last edit: 9 years 7 months ago by Jerome.
9 years 7 months ago #265518
by Jerome
Please edit the HikaMarket discount class and replace
By
'.JHTML::_('hikaselect.radiolist', $values, 'data[discount][discount_target_vendor]' , 'onclick="hikamarket_discount_setVendor(this, true);" onchange="hikamarket_discount_setVendor(this, false);"', 'value', 'text', @$discount->discount_target_vendor).
'.JHTML::_('hikaselect.radiolist', $values, 'data[discount][discount_target_vendor]' , 'onclick="hikamarket_discount_setVendor(this, true);"', 'value', 'text', @$discount->discount_target_vendor).
