- Thank you received: 2
Products of different vendors
9 years 6 months ago - 9 years 6 months ago #268642
by woidl
Products of different vendors was created by woidl
-- HikaMarket version -- : 1.7.3
-- Joomla version -- : 3.5.6
-- PHP version -- : 5.6
-- Browser(s) name and version -- : ie,firefox,chrome...
I am using Hikamarket with different vendors.
Settings: ONE Vendor (every vendor gets paid himself directly)
When a user tries to add products from different vendors:
User cannot add a product from another vendor: that is as it should be
But there is NO alert message which tells the user that this is not possible.
There is only the regular popup which tells "your product was succesfully added...". Looks as the product was added correctly, but it was not.
Did I miss a setting in the backend?
Feel free to try:
products-different-vendors
Addition:
If deactivating "Add to cart Legacy"... this helps. Seems to be the Ajax part that avoids the right alert message.
Does this mean I have to use regular mode and not legacy? Always?
Feel free to try:
Addition:
Last edit: 9 years 6 months ago by woidl.
9 years 6 months ago #268661
by Jerome
Replied by Jerome on topic Products of different vendors
Unfortunately, the legacy add to cart popup does not handle all features provided by HikaShop 3 ; specially about the error messages explaining why a message cannot be added into the cart.
So HikaShop display the popup after the "add to cart" action, it does not check if the product is added or not.
HikaMarket does not have any link with that, it was a problematic of the old cart system and that's why we worked so hard to create HikaShop 3 and the new systems.
The following user(s) said Thank You: woidl
