Select multi tags on click (without holding ctrl)
9 years 2 months ago #278752 by ChristopheMG
-- HikaMarket version -- : 1.7.3
-- Joomla version -- : 3.8.0
-- PHP version -- : 7.1.4
-- Browser(s) name and version -- : CHROME 59.0.3071.104
-- Error-message(debug-mod must be tuned on) -- : Can't select multi Tags
I can add multi tags with a product, but I would like to be able without holding the ctrl key... Just clicking. How to make it possible ?
Then to unselect by clicking again, it would be better for mobile version.
By the way I can't update Hikashop Business, In Update/About I have the message: "You have the latest stable version of HikaShop Business: 3.1.1"
But the latest stable version is 3.2.0 apparently, I'll try to update manually soon (download zip and Install with the Manager).
9 years 2 months ago #278784 by Jerome
The "tags" is not handle by HikaShop or HikaMarket but by Joomla itself.
So the interface you have to select the tags is provided by the Joomla core.
You can see to customize it using the layout system ; but in our side, there is not much to do.
Time to create page: 0.039 seconds
