- Thank you received: 16
Understand how product images get updated
- PeterChain
8 years 9 months ago #288500
by PeterChain
Understand how product images get updated was created by PeterChain
-- HikaShop version -- : 3.3
-- HikaMarket version -- : 2.0.1
-- Joomla version -- : 3.8.5
-- PHP version -- : 7.1
I am developing a way to handle duplicated images with different names in a product.
I made some algorithm that executes after clicking Save or Apply in the hikamarket product form.
I run this code on the event trigger OnAfterUpdate but I apparently find that any change in the images box where images can be deleted, uploaded or reordered is not yet reflected at that point
so my code is processing images not under the changes the user has made but on how images were before entering to edit the product.
At least this is how it looks to me, is like the reordering, deletion and creation of images in the table ' hikashop_files' is made after the execution of trigger OnAfterUpdate.
Am I right?
Victor.
Am I right?
Victor.
8 years 9 months ago #288510
by Jerome
Replied by Jerome on topic Understand how product images get updated
The way that HikaMarket handle the product is the same than HikaShop is handling the products.
Using the HikaShop trigger "onAfterProductUpdate", you will get the same content from HikaShop than from HikaMarket ; but depending the HikaMarket ACL, the product could have less data (for what the vendor cannot access).
Regarding the images ; they are processed after the trigger by the HikaShop core (same for HikaMarket).
You can see the code in "backSaveForm" or "frontSaveForm" (depending if you're in HikaShop or HikaMarket).
First will call :
And the second will call :
(where productClass is the HikaShop product class ; so the exact same function is called).
First will call :
$this->updateFiles($product, $status, 'images', $product->imagesorder);
$productClass->updateFiles($product, $status, 'images', $product->imagesorder);
The following user(s) said Thank You: PeterChain
