- Thank you received: 1
Allow Vendors to add products only after..
7 years 8 months ago - 7 years 8 months ago #304382
by onereik
Allow Vendors to add products only after.. was created by onereik
Is it possible to allow vendors to be able to add products only after they fill some required fields?
Or in other words allow them to login and edit his profile to upload some required files, and allow him to add items only after these required files are uploaded or sent.
Last edit: 7 years 8 months ago by onereik.
7 years 8 months ago #304387
by Jerome
Replied by Jerome on topic Allow Vendors to add products only after..
In the "limitation for vendors" section, you will find a setting called "Check vendor completion" ; it will limit the vendor capabilities until his profile is fully completed (no empty required field in its vendor profile).
7 years 8 months ago #304480
by onereik
Replied by onereik on topic Allow Vendors to add products only after..
Jerome,
Thank you for the reply, I already have made some customization in the component, however, I guess this feature is really good.
