- Thank you received: 13
Use product approvals to yes but products published
7 years 2 months ago - 7 years 2 months ago #310399
by verzevoul
Use product approvals to yes but products published was created by verzevoul
Hi!
1.I m trying to create a multivendor eshop. (everyting is uptodate).
Use product approvals is set to yes. But products are published without approval. I m sending screenshots.
2. My shop will be for services and products. Is it possible to have other template for products and other for services? I thought if it can be done by choossing the category. For example if the frondend vendor-user adds a product to the category services hikamarket loads the template for services...
Last edit: 7 years 2 months ago by Jerome. Reason: Removing PDF screenshots
7 years 2 months ago #310402
by Jerome
Replied by Jerome on topic Use product approvals to yes but products published
For your screenshots, please use jpeg or png files, not pdf.
Thank you for your understanding.
1- if your vendor have the approval ACL his products will be automaticallly approved.
2- yes. That's something done and related to HikaShop (and not HikaMarket)
7 years 2 months ago #310479
by verzevoul
Replied by verzevoul on topic Use product approvals to yes but products published
Ok for 1. we re good. Thanks
For 2 can you be more descriptive please?
How hikashop? I need this to be done from the front
7 years 2 months ago #310488
by Jerome
You should create a new topic, in the HikaShop section of the forum, for that part.
As I wrote juste before, HikaShop do manage the product template feature. So it's an HikaShop question, not an HikaMarket one.
