Product prices control
6 years 6 months ago #318928 by zetap
Product prices control was created by zetap
-- url of the page with the problem -- : www.abierto.uy/
-- HikaShop version -- : 4.2.3
-- HikaMarket version -- : 3.0.3
-- Joomla version -- : 3.9.18
-- PHP version -- : 7.3
-- Error-message(debug-mod must be tuned on) -- : Product prices control
Hello
I need to know if there is any way that when a vendor, from the frontend, publishes or edits a product, he cannot save it if the price is less than or equal to zero. Sellers find it difficult to understand the edition of a product perfectly and on many occasions by mistake, they publish their products without price.
Is it possible to do what i need?
Greetings thank you !
6 years 6 months ago #318929 by Jerome
Replied by Jerome on topic Product prices control
Did you try the "vendor options" (via HikaMarket > Access) and the "minimum price" rule ?
6 years 6 months ago #318965 by zetap
Replied by zetap on topic Product prices control
Hello, thanks for the answer
I had not reviewed that option, but I will need your help, because there is nothing configurable there, just a list but it is not editable. Attachment captures if useful.
6 years 6 months ago #318967 by Jerome
You have to click on the zone that you want to edit ; the system is like the dynamic edition in the HikaShop mass-action.
6 years 6 months ago #319065 by zetap
I did not understand how the configuration worked, now yes, add the value 1 as the minimum price for the selling user, but it does not work as expected, I can still publish a product without a price from the frontend, and it is shown in the listings as a free product.
I have attached a screenshot because maybe I'm still doing something wrong.
Greetings, thank you very much!
6 years 6 months ago #319069 by zetap
add more screenshot. thanks
6 years 6 months ago #319079 by Jerome
Thank you for the report.
Please download (or re-download) HikaMarket 3.1.0 ; I just put an hot-fix for that issue and improve the display of the error message in the same time.
6 years 6 months ago #319148 by zetap
Update to Hikashop 4.3.0 and Hikamarket 3.1.0, but no changes, even if you set the minimum price to "vendor options" (via HikaMarket> Access) and the "minimum price" rule
It is still possible to publish a product without price or with zero price.
Is there any other setting i need to change?
Thank you !
6 years 6 months ago #319194 by Jerome
Can you reproduce the issue in the demo website ?
Because just I tried and the patch is working :
pasteboard.co/J8w9ILf.png
pasteboard.co/J8wabwu.png
pasteboard.co/J8wajhE.png
6 years 6 months ago #319201 by zetap
Hello
Well, the difference between the screenshots you send me, pasteboard.co/J8wabwu.png and my configuration is the ACL part, in the sellers of my site, there is nothing marked in the ACL tab. What function does that configuration fulfill?
Thank you
6 years 6 months ago #319203 by zetap
Forget the screenshot
6 years 6 months ago #319205 by Jerome
The "Access" section allow to specify some restrictions and ACL depending the "vendor group".
It means that, by setting a group to the vendor, it will inherit the rules you have defined for that vendor.
You have settings in HikaMarket to link the "Vendor groups" with the "Vendor administrator" (the Joomla account referenced as "admin" for the vendor) groups.
But, if you don't want to configure your vendors ; you just have to set your rules for the group "Public".
When a vendor have no groups, HikaMarket will consider that the vendor is in "Public".
6 years 6 months ago #319226 by zetap
Hello
The truth is I do not understand much what you explain and if that is related to the fact that the minimum price rule does not work, to read you I use a translator and it may change the meaning of something.
I attach a screenshot and you tell me if that is the hikamarket configuration you are referring to and if that should be reflected in each vendor and if that is what does not allow me to configure the minimum price rule.
What worries me most is being able to configure the minimum price rule for sellers, I ask you to help me with that.
Thank you !
6 years 6 months ago #319229 by Jerome
Joomla do have "User Group" features.
You configured HikaMarket registration to set-up the group "Vendorer" to your users.
HikaMarket allow to set Groupe to vendors
We saw in one of your screenshots that your vendors to not have groups configured.
So : You need to configure the "minimum price" to the group public
6 years 6 months ago #319299 by zetap
Well I can tell you that the patch fo the minimum price rule works.
The problem that caused me not to configure it, is that the default assignment of user group is not done, if you look at the capture that I send you, in the configuration of HikaMarket -> registration options -> User group when registering , configure the "Vendedor" group to be assigned, but none of the registered vedors have an assigned group in the ACL tab of the vendor edit page in the backend.
I assigned to a trial seller manually the group "Vendedor" and the minimum price rule worked perfectly for that seller.
Will I need to configure something more so that the group "Vendedor" is assigned by default to all vendors that register?
Thank you !
6 years 6 months ago #319308 by Jerome
6 years 6 months ago #319359 by zetap
Hello
Thanks for the reply, but it doesn't work.
For the minimum price rule configured for the public group to work, I must check the vendor's ACL tab, the public group. It is the same situation no matter the group, if in the ACL tab there is a marked group, the rule does not work for that group, if it is done manually it works perfect, but, for what you indicate ti me, in the vendor ACL tab it should be marked By default the same user group checked in the hikamarket registration options settings, but that doesn't happen. So either I'm missing some settings I don't know about, or the user group inheritance defined in hikamaket isn't working.
Thank you !
Thank you !
6 years 6 months ago #319362 by Jerome
In your database, open the table "hikamarket_config" and add a new entry with the namekey "vendor_acl_default_public_group" and the value "1".
It will force the option to add by default the "public" group to all of your vendors.
6 years 6 months ago #319368 by zetap
Perfect, this is a solution, but isn't this a conflict? Because, if I see all the users who registered as vendors in the user management section of joomla, the user group they are assigned is actually "Vendedor" for the menus, for example, that works perfectly.
Is it not possible to force the group to be "Vendedor" in the vendor ACL?
Thank you !
6 years 6 months ago #319369 by Jerome
Time to create page: 0.135 seconds
