- Thank you received: 3
Product prices control
6 years 6 months ago #319496
by zetap
Replied by zetap on topic Product prices control
Hello
As you indicated, add the record in the namekey database "vendor_acl_default_public_group" and the value "1"
But it does not work, when registering a new vendor, in the vendor ACL tab, there is no group marked and the minimum price rule does not work.
It only works, if I manually mark the user group in the vendor ACL tab. At the moment with few registered vendors, I fix it manually, but it's not good to have to do it forever like this.
Could you help me solve it please.
Thank you very much, greetings!
6 years 6 months ago #319540
by Jerome
Replied by Jerome on topic Product prices control
I reproduced the configuration in a test website and the restriction is applied as it should.
The restriction :
pasteboard.co/J9ojZz1.png
The vendor groups (nothing) (otherwise it won't work) :
pasteboard.co/J9okqPX.png
The HikaMarket configuration table for the added entry :
pasteboard.co/J9okC4Q.png
My test :
pasteboard.co/J9okOrt.png
So, you should have something not set-up as I made and that's the point which should be modified.
The restriction :
My test :
6 years 6 months ago #319561
by zetap
Good Morning,
Well now if it works, thanks to the screenshots you sent me, I could see that I had added the settings in the wrong table in the database.
Fortunately it is resolved.
Thank you very much for your patience and attention. Greetings !
6 years 6 months ago #319562
by Jerome
Glad to know that the issue is resolved !
