- Thank you received: 18
Show vendors with their products into the backend
6 years 3 months ago #323226
by patoushka
Show vendors with their products into the backend was created by patoushka
is there a way to display all vendors and a list of their product in the backend? Actually, we have to go into the vendors section, click on a specific vendor and click on statistics. It will be good to have a summary module with some kind of a dashboard.
Does it exist? Is it possible?
Thanks,
Thanks,
6 years 3 months ago #323227
by patoushka
Replied by patoushka on topic Show vendors with their products into the backend
6 years 3 months ago #323334
by Jerome
Replied by Jerome on topic Show vendors with their products into the backend
Adding a filter for the vendor is related to HikaMarket "todo" list ; it is indeed something interesting.
For the display of the category, it would be related to the HikaShop core and would require a new thread in the HikaShop section of the forum.
6 years 3 months ago #323336
by patoushka
Thank you.
Is there an easier way for the superadmin to see which vendors have which products?
6 years 2 months ago #323353
by Jerome
The vendor profile in HikaMarket do list the vendor's products.
But in the HikaShop product listing, right now, the easier is to perform a view override to perform one SQL query and add the "vendor" column.
The plugin support is for my point of view, the best, but I still need some improvements to handle correctly the variants.
