Shipping not showing on products
5 years 5 months ago #333745 by DogPeople
Testing the config. I have shipping set to per vendor, and I have a free shipping option set up on my super admin account, that applies to the whole country. So it should apply to any product I create.
However, when I use another test user to "buy" an item, shipping is not visible in the cart.
What settings should I have to allow vendors to set up their own shipping, and ensure something actually shows up in the cart?
5 years 5 months ago #333750 by nicolas
Do you have the "shipping" view in your "checkout workflow" in the HikaShop configuration ? If not, it's normal you don't see the shipping on your checkout.
Also, you're talking about the "cart", not the checkout. Si if you're talking about the cart module, please note that in the settings of the cart module (in the Joomla modules manager) you have display settings to control what to display on the cart module, and one of them is to control if you want the shipping to appear or not. So maybe that's what you're talking about and what you need to change ?
5 years 5 months ago #333762 by DogPeople
My apologies. I meant checkout. See attached screenshots of the checkout WITHOUT shipping, the checkout workflow from Hikashop WITH shipping, the shipping option setup for the vendor account, and the shipping settings.
As mentioned, even though this shipping option is configured, there are no shipping options showing up on the checkout.
Please advise. Thanks.
5 years 5 months ago #333763 by DogPeople
Also, it's still showing
Plugin: at the top of the page. Still need to know how to remove that. Thanks!
5 years 5 months ago #333776 by Jerome
Does your product have a weight ?
Do you have the HikaShop setting "force shipping regardless of the weight" enabled ?
www.hikashop.com/support/documentation/5...ml#checkout_shipping
You first need to be sure that the shipping is enabled for your shop before starting test for the vendors.
Then you could see HikaMarket settings regarding the "shipping per vendor" and "Configuration of plugins by vendors" :
www.hikashop.com/support/documentation/1...onfig_market_general
5 years 5 months ago #333780 by DogPeople
Shipping regardless of weight seems to have solved the problem.
