- Thank you received: 42
Change default product order in cpanel
4 years 7 months ago - 4 years 7 months ago #340580
by trevsmiff
Change default product order in cpanel was created by trevsmiff
-- HikaShop version -- : HikaShop Business 4.5.0
-- HikaMarket version -- : HikaMarket Multivendor 4.1.0
-- Joomla version -- : 3.10.8
The order of products in the Hikamarket control panel defaults to 'ID Ascending' can I change it to default to 'ID Decending'?
Trevor
Trevor
Last edit: 4 years 7 months ago by trevsmiff.
4 years 7 months ago #340597
by Jerome
Replied by Jerome on topic Change default product order in cpanel
Yes, you can change it via hidden settings :
Hidden settings need to be added directly in the database, in the configuration table ( hikamarket_config )
In your case, only the second setting would be useful.
product_listing_default_sort_value ( "product.product_id")
product_listing_default_sort_dir ( "asc" / "desc" )
4 years 7 months ago #340598
by trevsmiff
Replied by trevsmiff on topic Change default product order in cpanel
Thanks Jerome
Trevor
Trevor
