Next product wrong order
3 weeks 21 hours ago #100000424 by verzevoul
-- HikaShop version -- : 6.7.1
-- Joomla version -- : 6.2.0
-- Browser(s) name and version -- : Chrome 156.0
When you're in the 1st product of the category (in the product page) in the above URL, and you click the next button to see the next product, it redirects uou to the 3d product instead of the 2nd.
It does this in any random order i checked.
For example: the 1st product is 3011-001, the 2nd is 3011-002 etc as you will see in the link.
Why is this happening?
Thank you
3 weeks 18 hours ago #100000438 by nicolas
Replied by nicolas on topic Next product wrong order
This comes from a bug in HikaShop: when several products share the same position in a category (which often happens after an import), the previous and next buttons of the product page sorted those products in a random order, while the category listing sorts them by product ID. So the buttons could skip a product or jump back, as you saw with 3011-001 going to 3011-003.
It is fixed in the latest build of HikaShop 6.7.1. Download it from your account on our website and install it over your current HikaShop (same version number, so Joomla's updater will not offer it; your settings and data are kept). After that, the buttons follow the same order as the listing.
3 weeks 18 hours ago #100000440 by verzevoul
Replied by verzevoul on topic Next product wrong order
I installed the latest Hikashop just now but it still does it wrong.
Can i send you credentials to check?
Thank you
3 weeks 15 hours ago #100000448 by mohairbears
I have the same issue? I would expect the next button to move to the next product in the order that is listed in its category? "NOT" the ID umber but the 'Order' number which we can choose ourselves?
3 weeks 15 hours ago #100000447 by nicolas
Thank you for testing. You were right, the first fix did not cover your case. On your site, many products belong to several categories. The product page addresses do not carry the category you came from, so the previous and next buttons used each product's first category instead of "Μεταλλικά κρεβάτια". That is why 3011-001 jumps to 3011-003 and its previous button goes to 3013-019, a product from another category.
This is fixed in the latest build of HikaShop 6.7.1: the buttons now follow the category of the menu item you are browsing, as the breadcrumb already does. Please download it again from your account on our website and install it over your current HikaShop. The version number is the same, so Joomla's updater will not offer it. Your settings and data are kept.
No access to your site is needed unless this still doesn't help. If that's the case, you can provide them via our contact form.
