- Thank you received: 7
$product = $productClass->get($product_id); is accesssing the wrong product
- Markus Schnier
3 hours 56 minutes ago #100000788
by Markus Schnier
$product = $productClass->get($product_id); is accesssing the wrong product was created by Markus Schnier
www.2-rad-schwede.de/
-- HikaShop version -- : 6.8.2 Business
-- Joomla version -- : 5.4.10
-- PHP version -- : 8.4.28
-- Browser(s) name and version -- : Firefox 160.0
Im using a site module and Sourcerer to calculate financing options as part of the product description. I access the product price via the product based on the product_ID. The problem is that it's not the presented product.
Also strange. The related products (also presented via a site module) are also based on the wrong product and not on the shown one.
On my test site it's working but in production not. For test purposes I show some product details in the Finanzing tabs on the product site.
Any idea what is going wrong.
Thanks ,
Markus
Sourcecode :
Thanks ,
Markus
Sourcecode :
<p><br /><strong>Ratenkredit – Der flexible Kredit ab 0% Zinsen</strong><br />Beim Ratenkredit sind Sie absolut individuell unterwegs. Eine Finanzierung wie für Sie gemacht. Wählen Sie aus verschiedenen Finanzierungsalternativen - ab einem Nominalzins von 0% und Laufzeiten bis zu 48 Monaten – ganz auf Ihre spezielle Situation und Bedürfnisse zugeschnitten.</p>
<p> </p>
{source raw="true"}
<?php
// HikaShop laden
if (!@include_once(JPATH_ADMINISTRATOR . '/components/com_hikashop/helpers/helper.php')) {
return;
// Aktuelle Produkt-ID ermitteln
$product_id = (int) hikashop_getCID('product_id');
$RadPreis = 0;
if ($product_id > 0) {
// Produkt direkt aus HikaShop laden
$productClass = hikashop_get('class.product');
if ($product) {
// Produktpreis inklusive HikaShop-Rabatten ermitteln
$currencyClass = hikashop_get('class.currency');
$ids = array($product_id);
$options = array('no_discounts' => false);
$currencyClass->getProductPrices(
$product,
$ids,
$options
// Endgültigen Bruttopreis übernehmen
if (!empty($product->prices)) {
$RadPreis = (float) $product->prices[0]->price_value_with_tax;
echo " Rad: ";
echo $product->product_name;
echo " / Code: ";
echo $product->product_code;
// Ab hier bisherige Berechnung
if ($RadPreis > 0) {
$Kredit6Rate = $RadPreis / 6.000114298777;
$Kredit6Zins = 0;
$Kredit12Rate = $RadPreis / 11.7556824543724;
$Kredit12Zins = $RadPreis / 48.0263157894737;
$Kredit36Rate = $RadPreis / 33.9553686934023;
$Kredit36Zins = $RadPreis / 16.6959887403237;
echo "<small><ul>";
echo "<li><strong>0% Ratenkredit mit 6 Monaten Laufzeit<br></strong>";
echo "Bei einem Nettodarlehensbetrag von " . number_format($RadPreis, 2, ',', '.') . " € entspricht dies einer monatlichen Rate von " . number_format($Kredit6Rate, 2, ',', '.') . " € mit einem Sollzins (p.a. fest) von 0% und einem Eff. Jahreszins von 0%. Zinsen insgesamt von " . number_format($Kredit6Zins, 2, ',', '.') . " € und einem Gesamtbetrag von " . number_format($RadPreis + $Kredit6Zins, 2, ',', '.') . " €.</br></br>";
