Product name and characteristics display wrong
15 years 4 months ago - 15 years 4 months ago #19349
by rikatos
Product name and characteristics display wrong was created by rikatos
I have a product with 4 characteristics.
Under System..Configuration..Display I have append characteristics name to product name as No, and Display the characteristics Name as No.
All I get displayed In the product page Is the value of the first characteristic (even though I have told it not to. I dont get the product name at all with the above settings.
I really wanted the product name followed by the characteristic name, but this doesnt seem to work either.
The site is currently at : redcell.co.uk/jonbuoy/index.php/browse-p.../category_pathway-14
This is the test site and the product in question. If I switch on the options above I get the Product name with the first characteristic, and it doesnt swap characteristic names from the drop down.
Joomla 1.6.3 and Hikashop 1.5.1 with rockettheme modulus
PS My main tax zone is 222 United Kingdom, but the country in cart always defaults to France.
Last edit: 15 years 4 months ago by rikatos.
15 years 4 months ago #19358
by rikatos
Replied by rikatos on topic Re: Product name and characteristics display wrong
OK, tried a standard default template, and the default template changes characteristics correctly (but doesn't like to only display the product name, so still a problem there). Its a rockettheme quirk!
I am finding more and more rockettheme quirks and would love any suggestions for different more consistent template builders.
The region still defaults to France even though my main zone is uk
15 years 4 months ago #19360
Replied by nicolas on topic Re: Product name and characteristics display wrong
You have the same problem as explained there for your RT template :
www.hikashop.com/support/forum/4-how-to/...e.html?lang=en#15467
We didn't had users with problems other than with joomlarts and rockettheme. So you should try the others.
You can change the address fields via the menu Display->Custom fields. There,you will be able to set the default value of the fields.
15 years 4 months ago #19457
by rikatos
Thanks to your link I was able to realise there was a spans ON/OFF option in the template so turned it off and hey presto all was working, once again thanks
