Having some initial problems
15 years 4 months ago #19484 by JamieC
Hi I'm trying to evaluate Hikashop and initially I must be doing something wrong because I have prices in a product but it's showing on the front end as "free"
I have three prices listed in my product (which I cannot delete either because there's no delete button for them?)
also the title look poor with the alias there too
www.sweetboutiqueusa.com/shop-online/pro...gory_pathway-13.html
any ideas?
15 years 4 months ago #19486 by nicolas
If the price is showing as free, it means that it couldn't find any price in your product. It usually happen when you don't specify a price with a minimum quantity of 0.
If you want to delete a price, just put 0 and save the product. The price will be removed automatically.
The title style is not working because you have that problem: www.hikashop.com/en/support/forum/3-bug-...s-display-wrong.html
The solution is also written there:
Thanks to your link I was able to realise there was a spans ON/OFF option in the template so turned it off and hey presto all was working, once again thanks
15 years 4 months ago - 15 years 4 months ago #19488 by JamieC
Thanks for the info - I am playing with the spans thing now - on the prices - I made the other prices 0 and now I have three "each" prices :)
but at least it's not free anymore! ;) so now I have three prices with 0 and all show up
EDIT: nevermind I figured out the 0 has to go in the price not qty - thanks!
thanks for your help
Last edit: 15 years 4 months ago by JamieC.
