Click manage variants without added characteristic
14 years 10 months ago - 14 years 10 months ago #32800
by mercury
Click manage variants without added characteristic was created by mercury
By mistake I clicked managed variants button in a product page without having added before a characteristic to the product. This had a result of keep receiving at Firefox the following error message and not being able anymore to login.
Secure Connection Failed
An error occurred during a connection to www...
SSL received a record that exceeded the maximum permissible length.
Error code: ssl_error_rx_record_too_long)
The page you are trying to view can not be shown because the authenticity of the received data could not be verified.
Please contact the web site owners to inform them of this problem. Alternatively, use the command found in the help menu to report this broken site.
Last edit: 14 years 10 months ago by mercury.
14 years 10 months ago #32820
Replied by nicolas on topic Re: Click manage variants without added characteristic
That should not produce such problems. Could you try to access to your backend with another browser ? Does it work ?
If so, you should clear your browser's cache and try again.
I see that you're using HTTPS to access your back end and that the SSL connection for the HTTPS requests cannot be established. You should try to connect to it with HTTP instead of HTTPS.
14 years 10 months ago #32864
by mercury
Replied by mercury on topic Re: Click manage variants without added characteristic
Followed your advice and problem solved. Your assistance is much appreciated. Thank you.
