- Thank you received: 2
Small problem using products comparison
14 years 10 months ago #33516
by mett
Small problem using products comparison was created by mett
Tested with 2 different joomla templates and having same problem: when i compare 2 or more products, all modules from left side are displayed below the comparison area (see attached image)
P.S: not a bug, but a feature request: the "Compare products" button would be better to appear only if at least 2 products are selected from list, or a warning message to be displayed and ask to tick more than one product from list.
14 years 10 months ago #33558
Replied by nicolas on topic Re: Small problem using products comparison
We don't have that problem on our end. I just tried and it worked ok. Could you give the link to that page so that we can see its HTML ?
Your proposition is good.You can change that by editing the file "listing" of the view "product" via the menu Display->Views and changing the line:
if(compare_list.length == 0 ) {
if(compare_list.length < 2 ) {
14 years 10 months ago #33600
by mett
Replied by mett on topic Re: Small problem using products comparison
our site is resticted to public access, but i can send you a PM with login data
14 years 10 months ago #33628
Yes. You can use our contact form for that:
www.hikashop.com/en/support/contact-us.html
Please also give the URL of that topic so that we know why you're sending the access.
14 years 10 months ago #33635
by mett
Message sent, thank you
14 years 10 months ago #33667
There is a closing div tag missing on that page.
Please edit the file "compare" of the view "product" via the menu Display->Views and add the line:
</div>
at the end of the file and that should solve the problem.
</div>
