Add text to product listing page
14 years 10 months ago #33988 by mortk1
I want to insert a paragraph of text at the top of each products listing page above the product thumbnails.
How can I do this?
14 years 10 months ago #34033 by nicolas
If that's the same text all the time, you could edit the file "listing" of the view "product" via the menu Display->Views to add your text at the top.
Otherwise, you could turn on the "show description" option of your modules/menus via the menu Display>content modules/menus and add a different text for each categories of your shop.
14 years 10 months ago #34109 by mortk1
Thank you for your quick response.
A few follow-up questions please:
1) If for example I wanted to place the text: "My Text" at the top of each product listing page, what new code should I add to the "listing" file and where would I place this code?
2) Once I have turned on the "show description" option of the modules/menus via the menu Display>Content menus, where would I go to place the text that I want to add?
14 years 10 months ago #34148 by nicolas
1. You could add the text "My Text" directly at the beginning of that listing view file.
2. In the menu Products->Categories, edit the corresponding category and add it in the description of the category.
14 years 10 months ago #34234 by mortk1
This is great...thanks!
