[SOLVED] : breadcrumb trail for cats in products
14 years 9 months ago - 14 years 5 months ago #37620 by rikatos
Hi.
I have a sugggestion which has bugged me for quite a while.
I have products located in different categories, this is one the the great things about hikashop how you make the product then just link it into as many different categories as you like. Theres is one problem though.
An example is needed :)
If I have a category called
Leisure..liferafts...Accessories
and another category called
Commercial..liferafts...Accessories
The base products (liferafts) are different but the accessories are all the same, so good old hikashop makes this very easy for me to link the accessories to both categories, excellant ! BUT on the category list they look identical :( yes I know there is a ID at the end, but tbh that doesnt really realte anything to me in the real world as I dont know the IDs :)
Last edit: 14 years 5 months ago by rikatos.
The following user(s) said Thank You: uteco
14 years 9 months ago #37662 by many-feathers
I definitely subscribe to this! I logged in to make this same suggestion, just to see it rikatos beat me to it! :) Shouldn't really be difficult to implement I guess?
14 years 9 months ago - 14 years 9 months ago #37664 by Jerome
In order to summarize and understand, you want that the name displayed in the category listing (your screenshot) contains the "full name" ?
Like: "Leisure / liferafts / Accessories" instead of "Accessories" ?
Last edit: 14 years 9 months ago by Jerome.
14 years 9 months ago #38000 by many-feathers
Yes, that would be great to be able to identify the correct category when multiple categories with the same name are selected.
Thank!
14 years 9 months ago #38070 by nicolas
It's in the todo list.
14 years 9 months ago - 14 years 9 months ago #38090 by rikatos
Sorry took so long to reply, yes nicolas, exactly that :) and thanks for putting on the to do list :)
Last edit: 14 years 9 months ago by rikatos.
14 years 6 months ago #48153 by rikatos
Hi there
I was just checking back on this to do. I am now in need of this quite bad as my shop has 6 main categories with subcategories that could all be the same name ! it is difficult to know which of the sub categories is one to remove or add at the moment.
14 years 6 months ago #48222 by nicolas
We'll look at that for next release
The following user(s) said Thank You: rikatos
14 years 6 months ago #48237 by many-feathers
That's good news! We're also waiting for this... :) Thanks!
14 years 6 months ago #48243 by rikatos
Aye it is :) I am so looking forward to it, kinda sad really !
14 years 5 months ago #52763 by rikatos
marked as solved as its implemented in the latest hikashop, and its all I ever wanted so THANKS guys :)
