- Thank you received: 2
double voting at products
- rockoladeluxe
14 years 7 months ago #45537
by rockoladeluxe
double voting at products was created by rockoladeluxe
14 years 7 months ago #45655
Replied by nicolas on topic Re: double voting at products
Could you do a screenshot of the vote tab of the configuration so that we can try to reproduce the problem ?
- rockoladeluxe
14 years 7 months ago #45731
by rockoladeluxe
Replied by rockoladeluxe on topic Re: double voting at products
14 years 6 months ago - 14 years 6 months ago #47149
by Xavier
Replied by Xavier on topic Re: double voting at products
Hi rockoladeluxe,
This problem have been corrected recently, it come from the name and the id for the vote module which are the same.
So some explorer don't make the difference between the both, that's why the stars of the comment module are called at the same time than the stars of the vote module.
In the next release this bug is corrected, but you can correct it by yourself if you want.
It involves some modifications.
Edit the file: YourSite/component/com_hikashop/views/vote/tmpl/form.php
Change:
And edit the file: YourSite/administrator/component/com_hikashop/classes/vote.php
Replace all the:
Change:
echo "<select name='hikashop_vote_rating' id='hikashop_vote_rating' style='display:none;'>";
TO
echo '<select name="hikashop_vote_rating" id="hikashop_vote_rating_id">';
Replace all the:
TO
Last edit: 14 years 6 months ago by Xavier.
- rockoladeluxe
14 years 6 months ago #47158
by rockoladeluxe
Hi Xavier,
thanks for the anwser, I'm working with Firefox11 and Chromium for Ubuntu 11.10.
I did the changes then cleared my cache but the double voting is still here.
- rockoladeluxe
14 years 6 months ago #47159
by rockoladeluxe
Hi Xavier,
I did the 2 changes you described and then cleared my cache but the double voting is still here...
Thanks,
Roy
Thanks,
Roy
14 years 6 months ago #47164
by Xavier
We are going to correct it.
If you only use the vote system and no the comments.
Try to comment the line:
In HikaShop > Display > Views, edit: product / show.php or (show_default.php) it depends of your version of hikashop.
echo hikashop_getLayout('vote', 'form', $params, $js);
