- Thank you received: 1
Show cats and products in HikaShop in a cool way!
14 years 4 months ago - 14 years 4 months ago #54345
by Hoang
Show cats and products in HikaShop in a cool way! was created by Hoang
Hi guys,
Skyline HikaShop Nested Accordion is a module of Joomla! that displays HikaShop categories as multilevel accordion menu. The accordion effect is written in native mootools javascript which is supported by Joomla! core so that there will be no javascript conflict when you use this module.
Try this here .
Thank you.
Try this here .
Thank you.
Last edit: 14 years 4 months ago by Hoang.
14 years 4 months ago #54375
Replied by nicolas on topic Re: Show cats and products in HikaShop in a cool way!
That's great !
Thank you for sharing that !
That's great !
14 years 2 weeks ago #73243
by ponygirl
Replied by ponygirl on topic Re: Show cats and products in HikaShop in a cool way!
is there any way to sort the catagories in alphabetical order????
14 years 2 weeks ago #73247
In hikashop categories listing modules, you can go in the hikashop options of the modules and select the ordering column and the ordering direction options for that.
14 years 2 weeks ago #73248
by ponygirl
Thanks Nicolas but i tried that and this is related to the Skyline Accordian Menu so probably not your area of support
The module installs fine but the category name order is out sync
$query->select('a.*')
->from('#__hikashop_category AS a')
->join('INNER', '#__hikashop_category AS b ON a.category_left BETWEEN b.category_left AND b.category_right')
->where('b.category_type = \'product\'')
->where('b.category_parent_id > 1')
->where('b.category_published = 1')
->order('a.category_left , a.category_ordering ')
14 years 2 weeks ago - 14 years 2 weeks ago #73249
You shoudl change:
->order('a.category_left , a.category_name')
Last edit: 14 years 2 weeks ago by nicolas.
14 years 2 weeks ago #73250
by ponygirl
Thanks again but i tried that and it did not work.
see attached. I have raised a support ticket with Skyline a few days ago but they are not as quick with giving support as you are
14 years 2 weeks ago #73251
Than I don't know. You'll have to wait for their answer.
The following user(s) said Thank You: ponygirl
