Disable add to cart button for some products
14 years 4 months ago #55622 by d4rkcloud
is there any way to hide the add to cart button for some product?
I'd like to have some product that i want to show online, but without the possibility to add it to cart.
Is it possibile?
Thanks! ;)
14 years 4 months ago - 14 years 4 months ago #55628 by Mohamed Thelji
Yes, can for example :
- Set the quantity of your product to 0
OR
- Set the price of your product to 0
- Go to "Hikashop->System->Configuration->Display"
- Set the "Display 'add to cart' button for free products" to NO
Hope this will help you a little :).
Last edit: 14 years 4 months ago by Mohamed Thelji.
14 years 4 months ago #55631 by d4rkcloud
Ok, this could be a solution.
But what should i do if the customer asnwers me that he wants to see the price but not the cart...? :blink:
14 years 4 months ago #55648 by Mohamed Thelji
You should use the first solution, then the price will be displaid :).
The following user(s) said Thank You: d4rkcloud
14 years 4 months ago #55683 by d4rkcloud
Good!
Thank you! :woohoo:
