SOLVED - Product code display
14 years 3 months ago - 14 years 3 months ago #59302 by donig
I need to display the product code near the product name (Joomla! 2.5.6, HikaShop Business 1.5.8).
I found how to do that in the hikashop's documentation ( www.hikashop.com/support/documentation/8...ng.html#product_code ).
I removed ".hikashop_product_code_main{ display:none; }" from the frontend_custom.css file but the code doesn't show up.
Joomla! 2.5.6
Hikashop Business 1.6.0
Last edit: 14 years 3 months ago by donig. Reason: SOLVED
14 years 3 months ago #59340 by nicolas
Replied by nicolas on topic Re: Product code display
Please make sure that the "show product code" option of the configuration is turned on.
The following user(s) said Thank You: donig, max.mandias
14 years 3 months ago - 14 years 3 months ago #59361 by donig
Replied by donig on topic Re: Product code display
Yes, it wasn't turned on, now it's ok.
I kept the line ".hikashop_product_code_main{ display:none; }" replacing the "none" value with "inline".
But I want to show the product code below the product name, with different text format and preceded with the words "Product code".
for example:
Product name
Product code: 1234
What I must edit for that?
Joomla! 2.5.6
14 years 3 months ago - 14 years 2 months ago #59420 by nicolas
You will have to edit the file "show_default" of the view "product" via the menu Display->Views and change that line:
echo $this->element->product_code;
echo '<br/>Product code: '.$this->element->product_code;
Last edit: 14 years 2 months ago by nicolas.
14 years 2 months ago #60935 by QuantumView
I tried the noted change, but it did not work for me. When I made the code change, the product page would not load and indicated that either the website was down for maintenance or that there was a programming error. Do you recommend any way for me to get this to work?
Also, when I do get it to work, how would I get the page to display the product code in a smaller font just as the other poster showed.
Thank you!
14 years 2 months ago #61026 by nicolas
It means that you didn't do the modification properly.
Please do a screenshot of your modification so that we can see what you did.
Also, if you want to change the font size, you can do like that:
echo '<br/>Product code: <span style="font-size:12px;">'.$this->element->product_code.'</span>';
14 years 2 months ago - 14 years 2 months ago #61100 by donig
This is what I've done for my case:
- for displaying the product code under the product name, with a different format (for example: paradoxshop.ro/index.php/produs/273-capa...ta-atos-set-4-bucati ), I edited two files:
1. show_reversed.php (because I use the reversed view for the product display) from HikaShop menu: Display\Views, frontend.
original:
</span>
<?php if ($this->config->get('show_code')) { ?>
<span id="hikashop_product_code_main" class="hikashop_product_code_main">
<?php
</span>
modified:
</span>
<?php
echo "<br />Cod produs: ";
</span>
2. frontend_custom.css: I added my wanted format.
/* different parts of the show of a product */
display:inline;
font-family:Verdana,Arial,Helvetica,sans-serif;
font-size:14px;
color: #7f7f7f;
Joomla! 2.5.6
Last edit: 14 years 2 months ago by donig.
The following user(s) said Thank You: nicolas, max.mandias
14 years 2 months ago #61116 by QuantumView
Thank you Nicolas and donig!
I was able to get this to work. I did use donig's method and it worked perfectly.
13 years 1 week ago #130542 by PubSite
Replied by PubSite on topic Re: Product code display
It works perfectly. But how if we want to do this for two languages? how can we implement this code for two different languages? any suggestions?!
13 years 1 week ago #130556 by nicolas
Then instead of :
you can use:
echo '<br/>'.JText::_('MY_TRANSLATION').': '.$this->element->product_code;
and then add the translation key MY_TRANSLATION to the override area of each one of your languages via the Languages tab of the configuration like that:
MY_TRANSLATION="My text"
The following user(s) said Thank You: PubSite
12 years 10 months ago #137253 by PubSite
Dear Nicolas I've been trying to add the same thing to BANK TRANSFER since we use two languages and it doesn't work. it shows me the exact KEY without translating it. Take a look please :
www.dropbox.com/s/yquia30ol79996t/Screen...12-19%2021.41.52.png
www.dropbox.com/s/1a9z9b3jjwki9is/Screen...12-19%2021.41.59.png
How can you help me? :) thanks in advance
12 years 10 months ago #137277 by nicolas
Remove all the text in that field and only have a translation key in it. Then, you can add all you text as the translation value of that translation key in each language.
12 years 10 months ago #137286 by PubSite
All I see is the Key I've entered. BANK_NAME as you can see here : www.dropbox.com/s/cfgxfc95mhe404e/Screen...12-20%2002.04.48.png
12 years 10 months ago #137288 by nicolas
Then you didn't add the translation override properly for your BANK_NAME translation key or you have spaces/line returns in that "information" field where you entered your translation key.
12 years 10 months ago #137291 by PubSite
Here are two pictures that show how I've entered my Override and Key.. where am I wrong?
www.dropbox.com/s/9se60v6i7fy79a5/Screen...12-20%2002.13.18.png
www.dropbox.com/s/6t4sw364hlffds5/Screen...12-20%2002.14.39.png
12 years 10 months ago #137295 by PubSite
I found out the problem I had. Thanks Nicolas, it's now SOLVED and working perfectly. Thanks again.
Time to create page: 0.120 seconds
