product code is missing on the product detail page
14 years 1 month ago #66400 by jan2
product code is missing on the product detail page.
I only see the product code in the product overview.
"Default parameters for products" in the Display menu
Display product code is activated.
Br
Jan
14 years 1 month ago #66431 by Xavier
Hi jan2,
Can you check if you have the code:
<?php if ($this->config->get('show_code')) { ?> <span id="hikashop_product_code_main" class="hikashop_product_code_main"> <?php echo $this->element->product_code; ?> </span> <?php } ?>
In the view "product / show_tabular" in HikaShop > Display > Views.
This is the same code used for the product overview.
You can remove the check (if), to always display the product code.
14 years 1 month ago #66434 by Mohamed Thelji
Hi Jan,
Do you have this CSS code in your front-end CSS file ("Hikashop->System->Configuration->Display") ?
.hikashop_product_code_main{ display:none; }
14 years 1 month ago #66506 by jan2
The CSS file is OK
and the file "product / show_tabular" is also ok.
14 years 1 month ago #66507 by Mohamed Thelji
I just wanted to tell you to remove this CSS code :).
14 years 1 month ago #66508 by jan2
do you mean I have to remove the complete code ?
also the CSS ?
14 years 1 month ago #66509 by jan2
it is working !
thank you
Time to create page: 0.099 seconds
