Order status language translation problem
13 years 11 months ago #77150 by abbakhan
Hi!
I cannot edit/translate the order status. The descripton field is normal, containing a text area, but there is no text field to translate the "Status name"
please view the image attached.
13 years 11 months ago #77189 by Jerome
We made a fix for the order status.
Please re-download HikaShop 2.0, it would fix the problem for the order status creation.
After that, if you want to edit or translate an order status, please you the Language override.
CREATED="created"
CANCELLED="cancelled"
etc...
13 years 11 months ago #77220 by abbakhan
I still cannot edit the new order status that I have created. I did not
understand the following part of your instruction:
CREATED="created"
etc...
Could you be more specific about that?
Could you please confirm that I have downloaded Hikashop as the latest
version here:
www.hikashop.com/en/account/your-orders/...r/show/cid-5684.html
if that is the correct one? As the package does not contain any
information about version, I'm not sure if that is the correct/latest
version.
Thank you!
13 years 11 months ago #77223 by Jerome
When you bought an HikaShop license, there is no version attached, you can download the latest version of HikaShop still your license is valid.
You can go into " Your account / Your subscriptions " to download the latest version.
In your backend, you can check your HikaShop thanks to the menu "Update / About".
Here the documentation about translations :
www.hikashop.com/en/support/documentation/faq.html#translation
13 years 11 months ago #77658 by abbakhan
Thank you for letting me know about the language override function!
Would you please be kind to advise about, how can I translate a new "Order status" lets call it "Packaging" created by me (not the Hikashop's default "Order Status")
13 years 11 months ago #77678 by Xavier
I think that you just have to add the translation in the language file, Packaging="Packaging".
HikaShop > Configuration > Languages.
13 years 11 months ago #77803 by abbakhan
You know and I knew that that cannot work. This is a bug. You know that its supposed to be translated in the edit interface (the image I have provided you in my first message), but its not. This problem has appeared after the last update. I did add couple of Statuses in previous version and did not have any problem with translatin.
13 years 11 months ago #77850 by Jerome
Did you re-download HikaShop 2.0 ?
13 years 11 months ago #77876 by abbakhan
Yes I have updated 3 days ago and I suppose after that no new version has been released
13 years 11 months ago #77945 by Jerome
Right, the previous fix didn't fix all of the problems.
I have made another tests and I have found your specific problem, so, the new package that I have just put online, would fix it.
Sorry for the inconvenient.
The following user(s) said Thank You: abbakhan
