Category and product column problem
13 years 2 months ago #120358
by mpourkos
Category and product column problem was created by mpourkos
merlinsmagicworld.com/
-- HikaShop version -- : 2.2.0
-- Joomla version -- : 2.5.14
-- PHP version -- : 5.3.27
although i set category and product columns at "3" i see only 1 column. i ve read some other posts but couldn't figure out what to do. Could you plz help?
The site is offline. Test user :
username : test
pass : test
username : test
pass : test
13 years 2 months ago #120367
Replied by nicolas on topic Category and product column problem
Your template doesn't support bootstrap. You need to turn off the option "use bootstrap design" of the configuration and it will work fine.
The following user(s) said Thank You: mpourkos
13 years 2 months ago #120667
by mpourkos
Replied by mpourkos on topic Category and product column problem
Thanks! That was the problem!
13 years 1 month ago #123076
by DeeEmm
Replied by DeeEmm on topic Category and product column problem
If you want to keep the responsive layout so that your site displays properly on mobile devices, but your template doesn't use bootstrap you can also simply include the relevant css to render the layout correctly.
.row-fluid {
width: 100%;
*zoom: 1;
.row-fluid:before,
.row-fluid:after {
display: table;
line-height: 0;
content: "";
.row-fluid:after {
clear: both;
.row-fluid [class*="span"] {
display: block;
float: left;
width: 100%;
min-height: 30px;
margin-left: 2.127659574468085%;
*margin-left: 2.074468085106383%;
-webkit-box-sizing: border-box;
-moz-box-sizing: border-box;
.row-fluid [class*="span"]:first-child {
margin-left: 0;
.row-fluid .controls-row [class*="span"] + [class*="span"] {
.row-fluid .span12 {
width: 100%;
*width: 99.94680851063829%;
.row-fluid .span11 {
width: 91.48936170212765%;
*width: 91.43617021276594%;
.row-fluid .span10 {
width: 82.97872340425532%;
*width: 82.92553191489361%;
.row-fluid .span9 {
width: 74.46808510638297%;
*width: 74.41489361702126%;
.row-fluid .span8 {
width: 65.95744680851064%;
*width: 65.90425531914893%;
.row-fluid .span7 {
width: 57.44680851063829%;
*width: 57.39361702127659%;
.row-fluid .span6 {
width: 48.93617021276595%;
*width: 48.88297872340425%;
.row-fluid .span5 {
width: 40.42553191489362%;
*width: 40.37234042553192%;
.row-fluid .span4 {
width: 31.914893617021278%;
*width: 31.861702127659576%;
.row-fluid .span3 {
width: 23.404255319148934%;
*width: 23.351063829787233%;
.row-fluid .span2 {
width: 14.893617021276595%;
*width: 14.840425531914894%;
.row-fluid .span1 {
width: 6.382978723404255%;
*width: 6.329787234042553%;
11 years 6 months ago #198220
by phil2010
Replied by phil2010 on topic Category and product column problem
Thanks for the very helpful css code that solves the one colum issue when using a dynamic layout on a bootstap template that might not have the relevent css for this layou.
Iused it by embeding within the desktop @media query
/* Large desktop */
@media (min-width: 1200px) {}
That way my tablet and mobile layout works in one colum,
To hikashop.... turning off bootstap so the shop only displays properly on desktop seem to be a bit of a cpoe out to a modern audience that is working with a dynmamic design. You might consider intergrating DeeEmm css into further responce in the future... just a thought
/* Large desktop */
11 years 6 months ago #198234
The CSS from DeeEmm is actually the CSS from bootstrap for responsive support.
Our plans are to actually support responsive display without bootstrap in the future. So something like that but different.
