Problem with responsive design
13 years 2 months ago #123536 by 121261
-- HikaShop version -- : 2.2.0
-- Joomla version -- : 2.5.14
Template is gavick - full responsive.
In hikashop on product category listning, on a desktop, when having boostrap design set to NO, we have 3 colums.
When I set boostrap design to ON, it changes to 1 column ON THE DESKTOP - looks awefull.
How can I get the 3 columns on desktop UNTIL the size goes down to ipad /iphone size...
can anybody help
regards
Bison
13 years 1 month ago #123537 by Jerome
HikaShop uses Bootstrap responsive design. If your template is not compatible with Bootstrap it won't work and you will see one single column for your listings.
At this moment you have to deactivate the "bootstrap design".
Bootstrap is the responsive framework chosen by Joomla, that's why we made an integration with this specific framework which is include in Joomla 3.
13 years 1 month ago #123793 by DeeEmm
Bison, this is an easy fix, I already posted a reply for this in another recent thread - www.hikashop.com/forum/product-category-...-column-problem.html
Basically all you need to do is include the bootstrap CSS in your Gavick template.
eg add the following to to the end of your site/templates/gacicktemplate/css/template.css
.row-fluid { width: 100%; *zoom: 1; } .row-fluid:before, .row-fluid:after { display: table; line-height: 0; content: ""; } .row-fluid:after { clear: both; } .row-fluid [class*="span"] { display: block; float: left; width: 100%; min-height: 30px; margin-left: 2.127659574468085%; *margin-left: 2.074468085106383%; -webkit-box-sizing: border-box; -moz-box-sizing: border-box; box-sizing: border-box; } .row-fluid [class*="span"]:first-child { margin-left: 0; } .row-fluid .controls-row [class*="span"] + [class*="span"] { margin-left: 2.127659574468085%; } .row-fluid .span12 { width: 100%; *width: 99.94680851063829%; } .row-fluid .span11 { width: 91.48936170212765%; *width: 91.43617021276594%; } .row-fluid .span10 { width: 82.97872340425532%; *width: 82.92553191489361%; } .row-fluid .span9 { width: 74.46808510638297%; *width: 74.41489361702126%; } .row-fluid .span8 { width: 65.95744680851064%; *width: 65.90425531914893%; } .row-fluid .span7 { width: 57.44680851063829%; *width: 57.39361702127659%; } .row-fluid .span6 { width: 48.93617021276595%; *width: 48.88297872340425%; } .row-fluid .span5 { width: 40.42553191489362%; *width: 40.37234042553192%; } .row-fluid .span4 { width: 31.914893617021278%; *width: 31.861702127659576%; } .row-fluid .span3 { width: 23.404255319148934%; *width: 23.351063829787233%; } .row-fluid .span2 { width: 14.893617021276595%; *width: 14.840425531914894%; } .row-fluid .span1 { width: 6.382978723404255%; *width: 6.329787234042553%; }
More info here if you are interested - deeemm.com/tutorials/73-hikashop/262-res...ut-without-bootstrap deeemm.com/tutorials/73-hikashop/262-res...ut-without-bootstrap
