product images size problem
13 years 1 month ago #129215 by Xavier
Replied by Xavier on topic Product & Category Display
1. Are you talking about the cart module ? If it is, you have to add a suffix to the module in the Joomla options, and then with some css add the image as background for the module and position it. Else, I don't know which "cart" text you are talking about :) But it's certainly possible.
2. You have to set a page for the "URL where you will be redirected when the cart is empty" option in Configuration > Main > Cart. And in the Paypal payment options you have to set an url for the return url parameter.
13 years 1 month ago #129285 by hopeful
Replied by hopeful on topic registration query
I edited the files "address_template" and changed the order of the tags but now the view cart page has changed (not showing quantity) and also the pop-up to say something has been added to the cart is not working ? Have you any ideas what went wrong?
13 years 1 month ago #129292 by hopeful
When I edited the files "address_template" in the views display window there is a column at the end of the address template row that says I can remove customization, should I do that or leave it. I am worried I might have done something wrong. Could me editing the address template have changed anything else like the pop-up window when an item is added to the cart. I also now can't seem to log on properly on the checkout page, the address does not show up at all. . Could you please have a look for me at www.tangyweb.com.au
13 years 1 month ago #129295 by hopeful
Replied by hopeful on topic Product & Category Display
I edited the "address_template" and changed the order of the tags but now the view cart page has changed and the pop-up to say something has been added to the cart isn't working, could me changing the address template have caused this. Also the address is now not showing up at all on the check-out page after log-in.
On the display view page where I selected the address template at the end of the address template row it says that I can remove customization, should I do this or leave it. I am concerned that I have messed something up by editing the address template.
www.tangyweb.com.au/
13 years 1 month ago #129346 by hopeful
Thank you for your help I think I just had a glich in the system. I have managed to fix the problem now and your instructions worked for the change of address
Thank you
13 years 4 weeks ago #129821 by hopeful
I wanted to add a "continue shopping" button to the view cart page and the checkout page.
I read some other peoples comments and tried to add a code to the cart template but it didn't work the code itself appeared on the checkout page. Below is the code I used. Could you please look at my site and see if I am doing the right thing
www.tangyweb.com.au
Thank you
$config =& hikashop_config();
$continueShopping = $config->get('continue_shopping', '');
if(!empty($continueShopping)) {
global $Itemid;
$url_itemid='';
if(!empty($Itemid)){
$url_itemid='&Itemid='.$Itemid;
if(strpos($continueShopping,'Itemid') === false) {
if(strpos($continueShopping,'index.php?') !== false) {
$continueShopping .= $url_itemid;
if(!preg_match('#^https?://#',$continueShopping)) $continueShopping = JURI::base().ltrim($continueShopping,'/');
echo $this->cart->displayButton(JText::_('CONTINUE_SHOPPING'),'continue_shopping',$this->params,JRoute::_($continueShopping),'window.location=\''.JRoute::_($continueShopping).'\';return false;','id="hikashop_checkout_shopping_button"');
13 years 4 weeks ago #129866 by Mohamed Thelji
Your code will display a "Continue shopping" button, but you'll have to set a value to the Continue shopping button's URL option through "Hikashop->System->Configuration->Checkout".
13 years 4 weeks ago #129976 by hopeful
Replied by hopeful on topic product images size problem
Thanks very much for all your help, I am new at this and trying to work my way through it.
Can you tell me what the URL value would be I should use.
Thank you
13 years 4 weeks ago #129977 by hopeful
I followed your instructions and great it worked, I now have a "continue shopping" button on the checkout page.
Can you now tell me how to get the "continue shopping" button on the "view cart" page?
Thank you
13 years 3 weeks ago #130061 by Xavier
Replied by Xavier on topic product images size problem
Can you be more precise about the "view cart" page ?
Which menu is it ? A "Cart display" menu ?
If it is, you will have to edit the view "cart / showcart" via the menu Display > Views and add html to display the button and link to the desired url.
13 years 3 weeks ago #130137 by hopeful
The "view cart" page is part of the main menu I think, and I would like to move the "proceed to checkout" button to the right of the screen and add either a "continue shopping" button or "back" button to the left of the screen. Also can you tell me how to edit this page so the image is lined up under the word "image". I have added a link to the " view cart" page if you could have a look for me. I appreciate your help.
www.tangyweb.com.au/index.php?option=com...ticle&id=8&Itemid=15
Thank you
13 years 3 weeks ago #130189 by Xavier
This page seems to be a joomla article. And the cart module is associated to this menu.
So to customize the page, you can edit the article with the id "8".
To customize the content of the cart, you have to edit the view "product / cart" via the menu Display > Views.
13 years 3 weeks ago #130336 by hopeful
Thanks, but is there a code I need to enter in the view "product/cart" in the Display>views to move the "proceed to checkout" button over to the right and add a "back" button or a "continue shopping button" to the left. I am very new at this and would appreciate your help. I f there is a code could you also show me where exactly to place it in "product/cart"
I also couldn't see how to move the image over to align with the word image on the view cart page once there is a product added to the cart.
Thanks again
13 years 3 weeks ago #130391 by Xavier
That's mainly css properties that are required, so you have to follow the previously given tutorial.
.hikashop_cart_module_product_image_title{text-align: center;} .hikashop_cart .hikashop_cart_input_button{float: right;}
To add a back button you will need some html like (found on google):
<input type="button" value="Back" onClick="javascript: history.go(-1)">
You can add it just before the code for the proceed to checkout button.
13 years 2 weeks ago #131126 by hopeful
firstly thanks for all the help so far.
Can you help me with a registration form problem?
On the registration form on the check-out page the 2 countries I have listed are Australia and New Zealand with Australia being the default country.
The problem is that the field titled "state" for Australia do not show up the states unless the customer clicks out of Australia and onto New Zealand and then clicks back to Australia, which obviously the customer doesn't know to do this. On the form the state is a compulsory field so can I fix this problem
Here is the link for the page on my site.
www.tangyweb.com.au/index.php?option=com...l=checkout&Itemid=16
13 years 2 weeks ago #131184 by Xavier
Replied by Xavier on topic registration query
It's a strange thing.
Thanks to try to try to publish back the zone France, then change the default country to France in the custom field, put back Australia, save. And then go to the states, and select the desired state, save.
Then unpublish the zone france.
The following user(s) said Thank You: hopeful
13 years 3 days ago #133689 by hopeful
I have just created a facebook page for my site "Preemiebabes"
Can you tell me where do I add the URL so when customers click on my facebook symbol on my website home page they actually go to my facebook page for Preemiebabes. Can you please be very specific as I am very unfamiliar with this
Thank you for all your help
13 years 1 day ago #133852 by nicolas
Replied by nicolas on topic registration query
We cannot tell you as it's not HikaShop which does that from what you're saying.
You will have to see that with the support of the extension which adds that facebook symbol on your frontend.
Maybe your template ?
