Problem with brands
13 years 1 month ago #126564 by DuFFi_SK
Problem with brands was created by DuFFi_SK
-- url of the page with the problem -- : www.lienocka.sk
-- HikaShop version -- : 2.2.1
-- Joomla version -- : 2.5.14
Hi, first I would like to thank you for the great product.
I am experiencing a problem with showing the brands pages. For example - I have products with a brand "Badger". When customer click on the product page to the name of the manufacturer "Badger" it should take him to the "Badger" page.
The problem is, that this is sometimes truth:
- www.lienocka.sk - click on "Bio aromaterapeutické produkty" , then on any product, and finally on "Badger"
and sometimes is not:
- www.lienocka.sk - move pointer to "Bio aromaterapeutické produkty", then click on any product from the menu, and finally on "Badger"
Thank you very much for your help.
13 years 1 month ago #126645 by Jerome
Replied by Jerome on topic Problem with brands
It's a menu id problem.
You have a working menu here :
www.lienocka.sk/lmenu-bio-aromaterapeuti...y/category/20-badger
And a non working menu here :
www.lienocka.sk/lmenu-bio-aromaterapeuti...m/category/20-badger
The second one is a product page menu so it can't handle correctly the link to a category listing.
13 years 1 month ago #126655 by DuFFi_SK
Replied by DuFFi_SK on topic Problem with brands
Thanks for answer. I understand, but how can I make the correct link to category listing from the second product page?
13 years 1 month ago #126731 by Xavier
Replied by Xavier on topic Problem with brands
You can probably edit the view "product / show_default" and replace :
if (!empty ($this->element->product_url)) { //DISPLAY the manufacturer echo JText :: sprintf('MANUFACTURER_URL', '<a href="' . $this->element->product_url . '" target="_blank">' . $this->element->product_url . '</a>'); }
By:
if (!empty ($this->element->product_url)) { //DISPLAY the manufacturer echo JText :: sprintf('MANUFACTURER_URL', '<a href="' . JUri::base().'lmenu-bio-aromaterapeuticke-produkty/category/'.$this->element->product_manufacturer_id . '" target="_blank">' . $this->element->product_url . '</a>'); }
13 years 1 month ago #126862 by DuFFi_SK
Hi Xavier,
can you please explain where is the view "product / show_default" located? Thanks
13 years 1 month ago #126866 by Jerome
In the HikaShop backend: Display > Views.
you have to edit the view "front-end | your_frontend_template | product | show_default".
12 years 10 months ago #138026 by jarinz
Replied by jarinz on topic Problem with brands
I have the same issue but it wasn't fixed the above view edit
where it doesn't work it adds ?Itemid= to the brand URL and shows no products, how can I fix this?
12 years 10 months ago #138034 by nicolas
Replied by nicolas on topic Problem with brands
You need to adapt the code we provided to the alias of your menu item.
12 years 10 months ago #138036 by jarinz
I'm not sure I know what that means. please have a look at our website is safka.co.nz and let me know what do we need to add into this code to make it work for all displayed modules?
12 years 10 months ago #138113 by nicolas
I don't understand what you want to do. This thread is about adding the brand on the product page. And you're talking about modules where you can't display product pages.
Please detail exactly what you want to do on which page (maybe with a link to the exact page and a screenshot showing where you want to add what?).
12 years 10 months ago #138179 by jarinz
this is about the link to Brands on the product page! they don't work when you click onto a product page from any displayed hikashop module.
Click on any product on our homepage www.safka.co.nz and the Brand link will not work!
for example you will land on this product page
safka.co.nz/index.php/component/hikashop...stmas-chocolate.html
the Brand link will point to safka.co.nz/index.php/component/hikashop...eregger.html?Itemid= which will not display any products from that brand
meanwhile, if you follow the product categories to the product pages, the Brands link works fine
for example from safka.co.nz/index.php/categories/category.html through to safka.co.nz/index.php/categories/categor...ing-ingredients.html to this prodict page safka.co.nz/index.php/categories/product...ory_pathway-107.html
the Brand link on that product page is safka.co.nz/index.php/categories/category/55-ruf.html and it works
I hope this clarifies the problem and you will be able to tell me how to fix it thanks
12 years 10 months ago #138258 by Mohamed Thelji
Replied by Mohamed Thelji on topic Problem with brands
Can you go :
- Go to "Hikashop->Display->Content modules"
- Go to the configuration page of the module which are displayed through "home" menu of your website.
- Make sure that you have set the "Menu" option of your Hikashop content modules to "Brands".
Hope this will solve your problem.
The following user(s) said Thank You: jarinz
12 years 10 months ago #138347 by jarinz
many thanks, that fixed it!
Time to create page: 0.104 seconds
