Default product title for variants
13 years 1 month ago #126628
by peteritv
Default product title for variants was created by peteritv
www.aswellascanbe.com/bobje/index.php/winkel
-- HikaShop version -- : 2.2.2 Business
-- Joomla version -- : 3.1.5
-- PHP version -- : 5.3.2
-- Browser(s) name and version -- : FireFox 24.0
Hi there!
In my test shop (see URL above) I created a product called "Jas 1" with 3 color variants. The main product is named "Jas 1" and (with "Manage Variants") I named the variants "Jas (Groen)", "Jas (Blauw)" and "Jas (Zwart)". The default variant is "Jas (Groen)".
Now when you enter the product detail page, it shows the name "Jas 1" while in my opinion it should show the name of the default variant: "Jas (Groen)".
When you now select one of the variants, the displayed product name correctly changes to (for instance) "Jas (Blauw)".
The same story goes for when I switch the option "Show default variant" to "Yes" in the main configuration...
Is this a small bug?
Thanks for all the good work guys,
Great product!
Peter
Hi there!
Great product!
Peter
13 years 1 month ago #126685
by Jerome
Replied by Jerome on topic Default product title for variants
Yes the first product variant is not load completely in the product page and the name of the product which is display is the name of the main product.
Because it is the name which is displayed in the product list, we didn't want to display a different name when the user open the product page, it could be confusing. But I understand that you want to display the first product variant name, with a little view override you can change it (in the "product | show_default" view).
The following user(s) said Thank You: peteritv
13 years 1 month ago #126806
by peteritv
Replied by peteritv on topic Default product title for variants
OK, not a big problem, so I'll leave it be for now.
Thanks Jerome
Thanks Jerome
11 years 6 days ago #219939
by goldian
Replied by goldian on topic Default product title for variants
I know this is an old thread but I actually want to display the variant name when the product detail page was first loaded up. What code do I change in the "product | show_default" view?
Thanks!
Thanks!
11 years 6 days ago #220002
Replied by nicolas on topic Default product title for variants
Remove the code:
in the file show_default via the menu Display>Views and that should do it.
Remove the code:
if (hikashop_getCID('product_id')!=$this->element->product_id && isset ($this->element->main->product_name))
echo $this->element->main->product_name;
else
11 years 6 days ago #220030
by goldian
Thanks Nicolas,
I have removed the code in line 14 (or 15) but it still does not work? The website is at westcoastbamboo.com.au/en/online-store/p...100-bamboo-sheet-set
Goldian
Goldian
11 years 6 days ago #220035
You're not using the "default" layout but the "tabular" layout.
So in that case, you need to do the same change but in the file "show_tabular" and not in "show_default".
10 years 5 months ago - 10 years 5 months ago #241705
by AntinJH
Replied by AntinJH on topic Default product title for variants
I have a little problem adding text in the product_show_default page. I want to add a texte under the price, which I did pretty easily with the show_defaut.php. But when I chose another variant (a different color) of my product, my extra text disapear !
Product page :
Variant product page :
Can you help me on this ?
Thanks !
Product page :
Thanks !
Last edit: 10 years 5 months ago by AntinJH.
10 years 5 months ago #241716
That's normal. You also need to do the change in the "show" file of the "product" view for the variants data.
The following user(s) said Thank You: AntinJH
10 years 5 months ago #241872
by AntinJH
Perfect. Thanks !
