add to wishlist appears for free products
13 years 1 month ago #126798 by kostalasa
-- url of the page with the problem -- : www.imgeater.com/blog
-- Joomla version -- : 3.1.5
-- PHP version -- : 5.3.10
Hello, when I set the Display 'add to cart' button for free products to NO, the button is replaced with "Add to wishlist", how can I configure it so that no button is displayed?
I have specifically set-up the shop NOT to display the wishlist, and the Add to Wishlist is set to NO.
Affected page: www.imgeater.com/blog/panoramic-photos
13 years 1 month ago #126807 by Jerome
I just upload a new package of HikaShop 2.2.2 with fixes for the "add to wishlist".
Please re-download HikaShop 2.2.2 and don't hesitate to tell us if you have any other problem with the wishlists.
13 years 1 month ago #126830 by kostalasa
I am afraid the issue persists, also the "new feature" add to wishlist button for the free products does not exist. Is there a quick fix I can do to hide the button?
13 years 1 month ago #126912 by Xavier
In the view "product / quantity" via the menu Display > Views, thanks to replace the code:
}elseif(hikashop_level(1) && !$this->config->get('display_add_to_cart_for_free_products') && $this->config->get('display_wishlist_for_free_products','1')){ $wishlistAjax = 'if(hikashopCheckChangeForm(\'item\''.$formName.')){ return hikashopModifyQuantity(\'' . (int)@$this->row->product_id . '\',field,1' . $formName . ',\'wishlist\','.$module_id.'); } else { return false; }'; echo '<div id="hikashop_add_wishlist">'; echo $this->cart->displayButton(JText::_('ADD_TO_WISHLIST'),'add',$this->params,$url,$wishlistAjax,'',@$this->row->product_max_per_order,1,'',false); echo '</div>'; }
By:
}elseif(hikashop_level(1) && !$this->config->get('display_add_to_cart_for_free_products') && $this->config->get('display_wishlist_for_free_products','1') && $config->get('enable_wishlist', 1)){ $wishlistAjax = 'if(hikashopCheckChangeForm(\'item\''.$formName.')){ return hikashopModifyQuantity(\'' . (int)@$this->row->product_id . '\',field,1' . $formName . ',\'wishlist\','.$module_id.'); } else { return false; }'; echo '<div id="hikashop_add_wishlist">'; echo $this->cart->displayButton(JText::_('ADD_TO_WISHLIST'),'add',$this->params,$url,$wishlistAjax,'',@$this->row->product_max_per_order,1,'',false); echo '</div>'; }
13 years 1 month ago #126931 by kostalasa
er, I got the Essential version, this is the code at the end of the view
}elseif(!$this->config->get('display_add_to_cart_for_free_products') && $this->config->get('display_wishlist_for_free_products','1')){
echo '</div>';
Also the display_wishlist_for_free_products does NOT exist on the database table.
Should I just add the && $config->get('enable_wishlist', 1) to the above code?
13 years 1 month ago #126935 by Xavier
Yes. :)
Or comment the three "echo" lines.
The following user(s) said Thank You: kostalasa
