Product not loading with more than 2 Characteristi
12 years 11 months ago #127825 by cboyd213
-- url of the page with the problem -- : coffeeflavorings.com/products/product/24...-flavor-station.html
-- HikaShop version -- : Starter: 2.2.2
-- Joomla version -- : 2.5.14
-- PHP version -- : 5.3.27
-- Browser(s) name and version -- : IE 9 (tried multiple browers all do the same thing)
Main page for product testing: coffeeflavorings.com/products.html
Issue is strange, if I add more than 2 Characteristics to a single product I get the error message below:
Fatal error: Maximum execution time of 30 seconds exceeded in /home/dwmenace/public_html/components/com_hikashop/views/product/view.html.php on line 1516
I check that file above for what's on line 1516 and it's: foreach($element->variants as $k => $variant){
Any ideas to why this is happening?
Thanks for your help!
12 years 11 months ago #127839 by Mohamed Thelji
Can you tell me how many variant do your have for your "gourmet flavor station" product ? or how many values do your have for each characteristics of your product ?
12 years 11 months ago #127860 by cboyd213
Yes each Characteristic has 23 values
12 years 11 months ago - 12 years 11 months ago #127878 by Mohamed Thelji
So you're trying to load 529 variants for your product, reading this thread will probably help you :
You can't have more than a few hundred of variants for a product.
If you need to much variants, you should consider using instead options:
www.hikashop.com/support/documentation/i...ct-form.html#options
or custom fields of the table "item":
www.hikashop.com/support/documentation/4...p-field-listing.html
instead of characteristics (or a combination)
Last edit: 12 years 11 months ago by Mohamed Thelji.
12 years 11 months ago #127883 by cboyd213
The links you posted doesn't work
I'm not sure what variants are but I don't see how I would have 529 of anything.
It's 1 product with 3 characteristics containing 23 values
so the total would be 69
12 years 11 months ago - 12 years 11 months ago #127888 by Mohamed Thelji
Regarding the links I just edited my last post.
Characteristics require a lot of memory/processing as it creates a variant of the product for each combination of the values of the characteristics and once the server hit the limit, it stops the processing. In your case it will create 23*23*23 = 12167 variants for your product.
If you have so much choices, you probably don't want a variant for each combination and thus you probably want to use something else like options or custom item fields which do not generate variants of each combinations and thus won't have that issue.
12 years 11 months ago #128096 by cboyd213
thanks for the reply
I just purchased the Hikashop business
and I for some reason just can't figure out how to add custom item fields to products.
I checked your link but it doesn't work.
I went to coffeeflavorings.com/administrator/index..._hikashop&ctrl=field
and added a table as item and for a dropdown
but how do I make it show up under the product?
There is nothing there to join the 2
12 years 11 months ago #128165 by Xavier
Do you have enabled the option "Front-end" ?
12 years 11 months ago #128170 by cboyd213
Thank you now it's show but having an issue with field type "signle dropdown"
it will only allow me 1 entry
Before editing it.
My Changes:
After saving my changes:
As you can see it drops all my changes
I need multiple items in a dropdown
12 years 11 months ago #128182 by Mohamed Thelji
You should put a "value" (like 1/2/3/....) for your single dropdown values, and then save.
The following user(s) said Thank You: cboyd213
Time to create page: 0.310 seconds
