2 View problems
13 years 3 weeks ago #128048 by Adidibau
2 View problems was created by Adidibau
-- HikaShop version -- :2.2.2 Business
-- Joomla version -- :3.1.5
-- PHP version -- :5.4
Capture 1 shows my first problem , this is a order made from 1 product with some options , i would like to only have quantity and Price on the main product.
My second problem is when i make a order. On the email that is sent to customer i would like to add the product description for the product ordered and for the options chosen, but i cannot fint the variable for the description.
Can someone please help with this.
/Jesper
13 years 3 weeks ago #128124 by Xavier
Replied by Xavier on topic 2 View problems
For the first one, I think that you just have to enable the option "Group options with product"
And regarding the email, the description is not loaded in the email, you have to get the product _id with "$item->product_id", and then get the product data with:
$productClass = hikashop_get('class.product'); $fullProduct = $productClass->get($item->product_id); echo $fullProduct->product_description;
13 years 3 weeks ago #128167 by Adidibau
Replied by Adidibau on topic 2 View problems
Thanks alot problem 1 solved :)
Sorry but im new at this product
Problem 2 i can just change in system - emails and then Order status notification insert the text in html file where i want it to be shown ?
13 years 3 weeks ago #128190 by Mohamed Thelji
Replied by Mohamed Thelji on topic 2 View problems
For your problem 2, you'll just have to add this code through the "HTML version" section of the page "Hikashop->System->Emails->'YourEmail'" :
<?php $productClass = hikashop_get('class.product'); $fullProduct = $productClass->get($item->product_id); echo $fullProduct->product_description; ?>
13 years 3 weeks ago #128233 by Adidibau
Hi Again
I have now tried to insert this and i only get a field in my email called description but not the text in the description
13 years 2 weeks ago #128311 by Mohamed Thelji
Ok, so can you show me how did you insert it ?
13 years 2 weeks ago #128333 by Adidibau
I inserted this part in php section
and then call this part Down in html
<p>
<span style="color:#1c8faf !important;font-size:12px;font-weight:bold;">{TXT:product_description} :</span>
</p>
I hope that was correct :)
Thanks in advance
13 years 2 weeks ago - 13 years 2 weeks ago #128367 by Mohamed Thelji
Like I told you, you should just add this code through the "HTML version" section of your email edition page :
Your should probably replace this code (that you have previously put through the "HTML version" section) :
<p> <span style="color:#1c8faf !important;font-size:12px;font-weight:bold;">{TXT:product_description} :</span> </p>
By :
<p> <span style="color:#1c8faf !important;font-size:12px;font-weight:bold;"> <?php $productClass = hikashop_get('class.product'); $fullProduct = $productClass->get($item->product_id); echo $fullProduct->product_description; ?> </span> </p>
Last edit: 13 years 2 weeks ago by Mohamed Thelji.
13 years 2 weeks ago #128383 by Adidibau
Hi Thanks
That did Work and took the Description for the main product , sorry its probably me that have not described my scenario correctly.
I have a Main product witch have some options and the options have some Characteristics.
Its the description for the Variants the Customer need there is some specific guidelines for customer on the different Variants
13 years 2 weeks ago #128428 by Jerome
Replied by Jerome on topic 2 View problems
Adidibau wrote: Its the description for the Variants the Customer need there is some specific guidelines for customer on the different Variants
Yes, not simple to understand the first time :)
Mohamed gives you something which can't work in the email. So please, don't use it.
The new templating system for the email is very flexible but we split the code and the design in two files.
You can still put some PHP code in the email but you can't mix the templating and the PHP like that.
In the file "your_email_name.preload.php" you will find this code
if($group){ foreach($data->cart->products as $j => $optionElement){ if($optionElement->order_product_option_parent_id != $item->order_product_id) continue; $item->order_product_price +=$optionElement->order_product_price; $item->order_product_tax +=$optionElement->order_product_tax; $item->order_product_total_price+=$optionElement->order_product_total_price; $item->order_product_total_price_no_vat+=$optionElement->order_product_total_price_no_vat; $t .= '<p class="hikashop_order_option_name">' . $optionElement->order_product_name; if($optionElement->order_product_price>0){ if($config->get('price_with_tax')){ $t .= ' ( + '.$currencyHelper->format($optionElement->order_product_price+$optionElement->order_product_tax,$data->order->order_currency_id).' )'; }else{ $t .= ' ( + '.$currencyHelper->format($optionElement->order_product_price,$data->order->order_currency_id).' )'; } } $t .= '</p>'; } } $cartProduct['PRODUCT_NAME'] = $t;
It put the "options" under the product name when the options are grouped.
You have to use the same kind of code in order to load the product description, but per product option.
$optionElement->product_id : will gives you the product id for the selected variant.
So you can add few lines
if($optionElement->order_product_price>0){ if($config->get('price_with_tax')){ $t .= ' ( + '.$currencyHelper->format($optionElement->order_product_price+$optionElement->order_product_tax,$data->order->order_currency_id).' )'; }else{ $t .= ' ( + '.$currencyHelper->format($optionElement->order_product_price,$data->order->order_currency_id).' )'; } // begin of lines to add if(empty($productClass)) $productClass = hikashop_get('class.product'); $fullProduct = $productClass->get($optionElement->product_id); $t .= '<br/>' . $fullProduct->product_description; // end of lines to add }
to add the description for each product option.
Hope it will help you.
The following user(s) said Thank You: Adidibau
13 years 2 weeks ago #128433 by Adidibau
Woow this is working :woohoo:
Thank you
is this something that can get deleted in a update
13 years 2 weeks ago #128453 by Jerome
Yes you can loose your modification with an update.
The best is to create a copy of the modified file and to rename it : "your_email_name.preload.modified.php"
At this moment, HikaShop will use the ".modified" file and the update will update the original one.
So you will still use your override without any problem.
If you create an override of the "preload", I will recommend you to check that the "your_email_name.html.modified.php" exists too (because the two files are very closed)
