Product Quantity and Product Display
13 years 3 weeks ago #130306 by domhan
Hi, I have managed to add the product quantity field to the Category Display of all products by using the code:
$this->params->set('show_quantity_field', 1);
This puts in a nice quantity box except it is way too big for the listing and just makes it over sized? Is there a way to make this smaller?
Also, is there a way of disabling the link to a single product page because I just want people to look at the category view and see all the products in that category and then from here they can choose quantities and add them to their cart.
Thanks, Dom.
13 years 2 weeks ago #130358 by Mohamed Thelji
1. Sure you'll be able to re-size your quantity box by using some CSS code.
2. You'll just have to just have to edit the content menu/module of your product listing through "Hikashop->Display->Content modules/menus", and set the Link to the product page option to NO.
13 years 2 weeks ago #130363 by domhan
Thanks for your reply. Is there any chance you could give me the CSS tags for the quantity box on the product page? I have already looked through the CSS code and changed the quantity box width to 10px but this did nothing.
www.dhdesign.org.uk/taste/index.php/wine/champagne this is the page I am wanting it on. I have disabled the function at the minute because it looked silly!
13 years 2 weeks ago - 13 years 2 weeks ago #130388 by Mohamed Thelji
I can't really help you if you disable the modifications that you've made, can you put them back so I can see what CSS code you'll need to apply ?
Last edit: 13 years 2 weeks ago by Mohamed Thelji.
13 years 2 weeks ago #130536 by domhan
Sorry, I have put them back now. If you could help me this would be very kind of you.
13 years 2 weeks ago #130561 by nicolas
This issue comes from your template CSS:
textarea, input, input[type="text"], input[type="password"], input[type="datetime"], input[type="datetime-local"], input[type="date"], input[type="month"], input[type="time"], input[type="week"], input[type="number"], input[type="email"], input[type="url"], input[type="search"], input[type="tel"], input[type="color"] { color: #6e6e6e; background-color: #ffffff; border: 1px solid #d5d5d5; border-radius: 4px; padding: 4px 8px; margin: 0; vertical-align: middle; width: auto; }
in www.dhdesign.org.uk/taste/templates/rt_a...fe9776dc07b12281.css
Please ask your template provider how to properly remove that code and it will display with a normal width.
13 years 2 weeks ago #131102 by teleactive
domhan wrote: Hi, I have managed to add the product quantity field to the Category Display of all products by using the code:
Thanks, Dom.
What file did you add the code to?
I need to do the same thing.
Thanks,
13 years 2 weeks ago #131111 by domhan
Hi there,
You go to the Hikashop component. Then on the top tabs, Display > Views.
Then at the top right there are some drop down menu's, Select "Product" and then in the middle one select your template. This will bring up a list of different views. Find the one called "listing_img_title" Open it.
Then scroll down until you see:
<!-- ADD TO CART BUTTON AREA --> <?php if($this->params->get('add_to_cart') || $this->params->get('add_to_wishlist')){ $this->setLayout('add_to_cart_listing'); echo $this->loadTemplate(); }?> <!-- EO ADD TO CART BUTTON AREA -->
I just added that line of code so mine looks like this.
<!-- ADD TO CART BUTTON AREA --> <?php if($this->params->get('add_to_cart') || $this->params->get('add_to_wishlist')){ $this->params->set('show_quantity_field', 1); $this->setLayout('add_to_cart_listing'); echo $this->loadTemplate(); }?> <!-- EO ADD TO CART BUTTON AREA -->
Thanks, Dom.
The following user(s) said Thank You: Xavier, teleactive
