Product Display Bootstrap - Options Overlap Mobile
12 years 11 months ago #135185 by foxy3433
-- Joomla version -- : 3.2
-- PHP version -- : 5.4
-- Browser(s) name and version -- : Google 31.0.1650.57
Couldn't find a answer for this specific to mobils
Please see attached image
PREVIOUS SENT TO WRONG CAT.....
12 years 11 months ago #135199 by Jerome
Are you sure you have the bootstrap design activated ?
(Or a template compatible with bootstrap).
I do not see elements which make me feel there is bootstrap in the page.
12 years 11 months ago #135202 by foxy3433
sent you login details to inspect via private message
12 years 11 months ago - 12 years 11 months ago #135204 by foxy3433
On desktop perfect -- Mobile once you go into product options - Looks a mess
Last edit: 12 years 11 months ago by foxy3433.
12 years 11 months ago #135216 by Jerome
Username and password do not match or you do not have an account yet.
12 years 11 months ago #135218 by foxy3433
try now -- didn't activate new account - should work fine now
12 years 11 months ago #135221 by Jerome
Your template have some bootstrap rules but it does not handle the bootstrap responsive rules.
I mean that, there is nothing which say that a "span6" on mobile device should be display in different lines ; like it is done in the official bootstrap responsive css.
getbootstrap.com/2.3.2/assets/css/bootstrap-responsive.css
@media (max-width: 767px) { [class*="span"], .uneditable-input[class*="span"], .row-fluid [class*="span"] { display: block; float: none; width: 100%; margin-left: 0; -webkit-box-sizing: border-box; -moz-box-sizing: border-box; box-sizing: border-box; } }
The following user(s) said Thank You: foxy3433
12 years 11 months ago #135225 by foxy3433
Cheets Jerome.. slapped that code into the bootstrap .css worked a treat Cheers chap!
12 years 7 months ago - 12 years 7 months ago #149752 by billkarv
Jerome wrote: Hi,
Thanks to this code I 've managed to display the categories to one column when the screen getting smaller. But I want to display the categories in 2 columns. How can I do that?
here is the link to my website.
christiantete-eshop.gr/joomlatest/index.php/brands
Last edit: 12 years 7 months ago by billkarv.
12 years 7 months ago #149931 by Xavier
It seems that you have solved you problem. The categories are displayed in two columns.
This is CSS things, so we suggest to find responsive tutorials to manage this kind of display.
12 years 7 months ago #150205 by billkarv
Xavier wrote: Hi,
Yes I found a solution but I didn't know if it was a good CSS practice.
Thank you for your response, I think I am finding my way through responsive layout "world".
Time to create page: 0.108 seconds
