options for product
12 years 10 months ago #136357
by amnondu
options for product was created by amnondu
www.delitiv.com/del2013/
-- HikaShop version -- : 2.2.3 HikaShop Essential
-- Joomla version --
.1.5
-- PHP version -- : 5.3.10
-- Browser(s) name and version -- : firefox 25.0.1
i would like to add to a product bit.ly/ITcDIi multiple option. for example in the gotdog item i would like to let the user to choose few component :ketchup,mustard, tomato ( the full list has 10 items ) .
the user should be able to choose more then one item .
please advice
please send replay to yoav@pitron10.com as well since the license was register for my client.....
thanks
yoav
.1.5-- PHP version -- : 5.3.10
please advice
thanks
yoav
- Thank you received: 1778
12 years 10 months ago #136381
by Mohamed Thelji
Replied by Mohamed Thelji on topic options for product
Hi yoav,
A solution can be to :
- Create an unpublished category
- Create 4 product named (ketchup/mustard/tomato/..) and add them to the unpublished category
- Go to your product configuration page
- add these products through the "Options" tab of your product configuration page.
12 years 10 months ago #136413
by amnondu
Replied by amnondu on topic options for product
O.K. IT WORKS how ever i get one long list can i built it into 2 or 3 coulmns ?
the filed for choosing products ( optional product ) is very wide can i make it smaller ? the only word there is yes \ no
www.delitiv.com/del2013/%D7%94%D7%96%D7%...97%D7%9E%D7%95%D7%AA
in addition i would like to give a customer an option to order with any hotdog meal one soft drink in 50% discount. .
the client will be able to choose only one soft drink cola,zero , sprite etc....if he order the hotdog meal .
please advice
yoav
please advice
yoav
12 years 10 months ago #136539
Replied by nicolas on topic options for product
Your link does not work anymore.
Instead of adding several products as options of your product, you should add only one product with a characteristic with all the possible values, like explained in the documentation: www.hikashop.com/support/documentation/i...ct-form.html#options
That way, you'll get an option dropdown with several values.
12 years 10 months ago #136638
by amnondu
but i would like the user to choose more then one product from the list ? can that be done ? how ?
12 years 10 months ago #136655
by Mohamed Thelji
The solution will be to create X characteristics with the same values, then add them to your product so that your customers will be able to select X time one of your characteristic value.
Time to create page: 0.133 seconds
