Displaying available products as less or more than
12 years 10 months ago #138880 by LAMF
-- url of the page with the problem -- : www.gobbe.se
-- HikaShop version -- : 2.2.3 Business
-- Joomla version -- : 2.5.17
-- PHP version -- : 5.3.3
-- Browser(s) name and version -- : Chrome 31.0.1650.63 m
-- Error-message(debug-mod must be tuned on) -- : Not necessary
Hi, Short question:
How can I set up HikaShop to display every products amount like below 5 left and more than 5 left instead of exact numbers of how many is left in stock?
I have seen plenty of shops displaying amount of products like this but how do I set it up?
Micke
12 years 10 months ago #138905 by Mohamed Thelji
The solution will probably be to edit the code of your "quantity" file of the "product" view of your front-end template through "Hikashop->Display->Views" , and change these lines :
<div class="hikashop_product_stock"> <?php echo '<span class="hikashop_product_stock_count">'.JText::sprintf('X_ITEMS_IN_STOCK',$this->row->product_quantity).'<br/></span>'; if($config->get('button_style','normal')=='css'){ echo '<br />'; } if($max<=0 || $max>$this->row->product_quantity) $max = $this->row->product_quantity; if($this->params->get('add_to_cart',1)){ echo $this->cart->displayButton(JText::_('ADD_TO_CART'),'add',$this->params,$url,$this->ajax,'',$max,$min); $btnType = 'wish'; } if(hikashop_level(1) && $this->params->get('add_to_wishlist') && $wishlistEnabled && !$hideForGuest && $this->config->get('display_add_to_wishlist_for_free_products','1')){ echo '<div id="hikashop_add_wishlist">'; echo $this->cart->displayButton(JText::_('ADD_TO_WISHLIST'),$btnType,$this->params,$url,$wishlistAjax,'',$max,$min,'',false); echo '</div>'; } }
Hope this will help you a little.
12 years 10 months ago #138988 by LAMF
Ok but as I'm no programmer I have no idea what to put in in order to display what I want,, :-(
I want for example the quantity to display lie this (in english to make you understand)*:
More than 5 pcs left (if the number left of this product is 5 or more than five items)
or
Less than 5 pcs left (if the number of that product is less than 5).
Maybe you can give me a hint how to do it?
12 years 10 months ago #139180 by Xavier
You have to replace:
By:
$qtyMessSet = 5; if($this->row->product_quantity >= $qtyMessSet || $this->row->product_quantity == '-1') echo ' <span class="hikashop_product_stock_count">'.JText::sprintf('MORE_THAN_X_ITEMS',$qtyMessSet).'<br/></span>'; else echo ' <span class="hikashop_product_stock_count">'.JText::sprintf('LESS_THAN_X_ITEMS',$qtyMessSet).'<br/></span>';
And add translations like:
MORE_THAN_X_ITEMS="More than %s pcs left"
LESS_THAN_X_ITEMS="Less than %s pcs left"
in the language file.
The following user(s) said Thank You: LAMF
12 years 10 months ago - 12 years 10 months ago #139186 by Mohamed Thelji
The solution will probably be to change this line :
By :
if($this->row->product_quantity < 5) echo '<span class="hikashop_product_stock_count">Less than 5 pcs left<br/></span>'; else echo '<span class="hikashop_product_stock_count">More than 5 pcs left<br/></span>';
Edit
Note that the solution that Xavier gave you will probably be better ;).
Last edit: 12 years 10 months ago by Mohamed Thelji.
12 years 10 months ago #139252 by LAMF
Ok thanks a lot guys! I ued Xaviers methd as I like to add the translation in the language file. :)
I have another question.
Is it possible to add quantity to multiple products at one go?
Can a cronjob do this and if so how can you do that?
Maybe it's possible to add all products in a CSV/Excel exported from HikaShop and edit the file and the product_quantity field for each of these products and then re-import it via the product import?
12 years 10 months ago - 12 years 10 months ago #139263 by LAMF
Just want to let you know it works and it saves a lot of work too :)
Jut export a product category with all products and edit the fields you want to change value in and save and upload and voila!
Last edit: 12 years 10 months ago by LAMF. Reason: more info added
3 years 3 months ago #354124 by nico.van.leeuwen
Hi, just wanted to ask if this solution is still OK with the new versions of HikaShop?
It's been more then 9 year :-)
3 years 3 months ago #354128 by Philip
Oui, ce code devrait marcher tel quel, le seul point potentiel à considérer serait peut être les classes qui ont potentiellement évolués.
Mais en partant de l'existant de votre HikaShop pour reprendre le principe de la modification ne devrait poser aucun souci.
Cordialement
