- Thank you received: 1
Product Description not shown in Product listing
- Marsipulami
- Joomla 3.0 Newbie :)
12 years 10 months ago #140506
by Marsipulami
You have to be patient with me
Product Description not shown in Product listing was created by Marsipulami
www.bodystuff.ch/danii/index.php/hikasho...for-products-listing
-- HikaShop version -- : Hika Starter 2.3.3
-- Joomla version -- : 3.2.1
-- PHP version -- : 5.3.23
Hi there
I am testing the hika shop with my new page. So far i'm very happy with it but there are some problems i couldn't get right. Here is my first one
Is is possible to show a little product desciption in the product listing?
I've turned the switch on for the descrition but nothting is shown.
Am i doing anything wrong?
Thanks for help
Marsipulami
Hi there
Thanks for help
Marsipulami
- Thank you received: 1778
12 years 10 months ago #140523
by Mohamed Thelji
Replied by Mohamed Thelji on topic Product Description not shown in Product listing
I think that you'll probably find your answer through this thread
- Marsipulami
12 years 10 months ago - 12 years 10 months ago #140529
by Marsipulami
Replied by Marsipulami on topic Product Description not shown in Product listing
Thanks for your answer
I tried the solution explained in this other thread.
But i couldn't find the code echo $this->row->product_name in the listing_table file of my template.
So i couln't put the new code after that line.
What am i doing wrong?
Is this the right file to change?
product / listing_table.php from my template (rt_lumiere)
Greets
Marsipulami
Greets
Marsipulami
Last edit: 12 years 10 months ago by Marsipulami.
12 years 10 months ago #140546
by Mohamed Thelji
My bad the solution was this answer :
You'll have to add this code :
after this :
and add this code :
after this :
<td class="hikashop_product_description_row">
<?php
echo $this->row->product_description; ?>
</td>
<?php if ($this->config->get('show_code')){ ?>
<td class="hikashop_product_code_row">
<?php if($this->params->get('link_to_product_page',1)){ ?>
<a href="<?php echo $link;?>">
<?php }
echo $this->row->product_code;
</a>
<?php } ?>
</td>
<?php } ?>
<th class="hikashop_product_description_title" align="center">
<?php echo JText::_( 'PRODUCT_DESCRIPTION' ); ?>
</th>
<?php if ($this->config->get('show_code')) { $columns++;?>
<th class="hikashop_product_code_title" align="center">
<?php echo JText::_( 'PRODUCT_CODE' ); ?>
</th>
<?php } ?>
- Marsipulami
12 years 10 months ago - 12 years 10 months ago #140549
by Marsipulami
Hi Mohamed
Thank you.
So far the description work.
But the problem is, that i only want the text before the mark "read more" is that possible?
The Idee is that in the product table, is only a short descrition of the product.
But in the product detail page, there will be more descrition for the linked product.
Best wishes
Marsipulami
Thank you.
Best wishes
Marsipulami
12 years 10 months ago - 12 years 10 months ago #140552
by Mohamed Thelji
Ok, so the best solution will probably to edit the code :
By :
Note that you'll have to replace the "NB_CHAR" word by the length of your category description.
<?php
</td>
<?php
if(strlen($this->row->product_description )> NB_CHAR)
echo substr($this->row->product_description, 0, NB_CHAR);
else
</td>
Last edit: 12 years 10 months ago by Mohamed Thelji.
- Marsipulami
12 years 10 months ago #140557
by Marsipulami
There must be an error in your code Mohamed
Parse error: syntax error, unexpected ';' in line 144
- Marsipulami
12 years 10 months ago #140558
by Marsipulami
ok found the error...was the point after nb_char)
but it doesn't cut the description with the number of char
12 years 10 months ago #140560
by Mohamed Thelji
My bad, here is the code to use :
<?php
else
</td>
The following user(s) said Thank You: Marsipulami
- Marsipulami
12 years 10 months ago - 12 years 10 months ago #140564
by Marsipulami
Damn...
Mohamed you're my man
Many thanks....it looks great like this.
That is a product listing, like it have to be
