Hikamarket Help
12 years 9 months ago #142236 by whatson1
Hikamarket Help was created by whatson1
Presently making a catalog using your Hika Market, and i am finding it hard going on several levels, been using joomla for the last 6 months now and have come to know this like the back of my hand, so please could you help me with these issues stated below i am trying to make this fool proof so anybody can add products with out thinking twice, here goes for issues
Question 1 - As i am creating a catalog only, how can i simplify the add item page - illustrated below, i really do not need half of the fields available in this section ( Meta description,Keywords,Alias,Canonical URL,Related products,Options)
Question 2 - Please could you look at the below attachment (Image 2) - i am having great difficultly understanding why the price is right aligned when all the other text is of left alignment, please could you assist me it finding a away have it all left aligned.
Question 3 -
Please could you tell me how to increase the child images below the main image - to make this more professional looking
Please could you get back as soon as possible
Thankyou in advance
12 years 9 months ago #142317 by Jerome
Replied by Jerome on topic Hikamarket Help
HikaMarket question
www.hikashop.com/support/documentation/1...et-presentation.html
HikaMarket uses the ACL to determine which field will be visible and editable in the front-end editor.
You have to tweak the default ACL or the vendor ACL in order to remove the "product / edit / ... " elements that you don't want your vendor access to.
You can also remove the right to edit categories, discounts, etc. You can really tweak all permissions.
HikaShop questions
Your price does not look right aligned but I think it is centered.
You can customize the HikaShop css in order to change the rules and the way that the price is aligned.
I will recommend you this page which explain how customize HikaShop : www.hikashop.com/support/support/documen...ize-the-display.html
It will be the global same thing for the thumbnails, you can customize the CSS rules applied on this elements to change the size, add some margin, etc.
If you really can't have the wanted design using CSS, you can override the view to customize the generated HTML (moving some blocks, etc).
Kind regards,
