SOLVED: Problem with Tabs
12 years 6 months ago #147608
by Xavier
Replied by Xavier on topic Problem with Tabs
Problem solved, I just edited the link to have the same than when the link is in the specification tab.
You can see the changes in the show_tabular view.
- Webmediacontent
- Thank you received: 1
12 years 6 months ago #147704
by Webmediacontent
Replied by Webmediacontent on topic Problem with Tabs
Hi xavier
Thank you very much. Works great. Only one small detail. The view of the target page is not the same.
This is the new link as a result of: www.maglo.ch/jupgrade2/index.php/shopkat...egory/38-val-di-toro
And so it is original: www.maglo.ch/jupgrade2/index.php/shopkat...egory/38-val-di-toro
I work with the table view.
greetings
Adrian
greetings
Adrian
12 years 6 months ago #147733
by Xavier
That should be ok now.
If it's not exactly what is expected, you can edit the view and see the examples of links I made and improve them as you wish.
The display was not the good one because the item id was missing.
- Webmediacontent
12 years 6 months ago - 12 years 6 months ago #147842
by Webmediacontent
Very very very thanks. This is perfect. Great Support.
For the other. This is the Code
<?php
$categoryClass = hikashop_get('class.category');
$manufacturer = $categoryClass->get($this->element->product_manufacturer_id);
$categoryClass->addAlias($manufacturer);
//echo JText::_('MANUFACTURER_ALL').''.'<a href="'.hikashop_completeLink('category&task=listing&cid='.$manufacturer->category_id.'&name='.$manufacturer->alias.'&Itemid='.$Itemid).'">'.$manufacturer->category_name.'</a>';
//echo JText::_('MANUFACTURER_ALL').''.'<a href="index.php/shopkat/category/'.$manufacturer->category_id.'-'.$manufacturer->alias.'">'.$manufacturer->category_name.'</a>';
echo JText::_('MANUFACTURER_ALL').''.'<a href="index.php?option=com_hikashop&ctrl=category&task=listing&cid='.$manufacturer->category_id.'&name='.$manufacturer->alias.'&Itemid=197">'.$manufacturer->category_name.'</a>';
anzeigen.</p>
Last edit: 12 years 6 months ago by Webmediacontent.
The following user(s) said Thank You: Xavier
12 years 6 months ago #147900
by Xavier
Thanks to have shared the complete code.
Time to create page: 0.188 seconds
