Problem with my cart, cant see Print icon.
12 years 8 months ago - 12 years 8 months ago #144371 by george1988
-- url of the page with the problem -- : md-test.ru/index.php/2014-01-28-18-35-30/2014-01-28-18-36-20
-- Joomla version -- : 3.2.1
-- PHP version -- : 5.2.17
-- Browser(s) name and version -- : ALL Safari, Firefox, IE, Chrome
-- Error-message(debug-mod must be tuned on) -- : there no error because i cant see the icon
I don't know what else I can do, everything is enabled at settings (I think) Using T3 template - t3-framework.org if adding manually print code to site its printing the whole page, and what I need is just to print the cart.
Last edit: 12 years 8 months ago by george1988.
12 years 8 months ago #144395 by Mohamed Thelji
Can you show me some screenshots of where do you exactly want to add you "print" button ?
12 years 8 months ago - 12 years 8 months ago #145269 by george1988
If possible I want to add the "Print" icon to my cart, the picture is below.
Thanks a lot.
12 years 8 months ago #145336 by Jerome
The print icon is available when you are displaying the cart but is not displayed in the cart module.
if you open the page " index.php?option=com_hikashop&ctrl=cart " you should see the print icon with the special link to print to cart.
Thanks this little HTML code and to the feature of view overrides, you can override the view "product | cart" and add the print icon like you want in the module.
More about view override :
www.hikashop.com/support/documentation/i...op-view-listing.html
www.hikashop.com/support/documentation/i...ashop-view-form.html
12 years 8 months ago #145406 by george1988
Jerome wrote: Hi,
:-/ any ideas how I can add it to the module?
12 years 8 months ago #145517 by Mohamed Thelji
There's already an option to do that, so you'll just have to set the "Allow users to print their cart" option to YES through "Hikashop->System->Configuration->Main->'cart'".
12 years 8 months ago #145847 by george1988
Mohamed Thelji wrote: Hi,
"Allow users to print their cart" is already enabled! but I see nothing! at the cart itself.
this is the reason why opened this thread. :huh:
12 years 8 months ago #145871 by Xavier
Had you edited the "product / cart" view via the menu Display > Views ?
If it is, that's maybe why you don't have the code lines for the print icon in the cart.
Thanks to try to edit that view, and remove the if condition around the print button.
12 years 7 months ago - 12 years 7 months ago #146430 by george1988
Xavier wrote: Hi,
Thanks for your reply, but everything seems fine with the product / cart I haven't edited it, can you look at it?
Can I just add some code at the top of the file to force the print icon always? my php programing skills not so high so would be nice of you if can help me with that, Thanks!
<?php /** * @package HikaShop for Joomla! * @version 2.2.3 * @author hikashop.com * @copyright (C) 2010-2013 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); ?><?php global $Itemid; $url_itemid=''; if(!empty($Itemid)){ $url_itemid='&Itemid='.$Itemid; } $this->setLayout('listing_price'); $this->params->set('show_quantity_field', 0); $desc = $this->params->get('msg'); $cart_type = $this->params->get('cart_type','cart'); if($cart_type == 'wishlist'){ $convertText = JText::_('WISHLIST_TO_CART'); $displayText = JText::_('DISPLAY_THE_WISHLIST'); $displayAllText = JText::_('DISPLAY_THE_WISHLISTS'); $emptyText = JText::_('WISHLIST_EMPTY'); }else{ $convertText = JText::_('CART_TO_WISHLIST'); $displayText = JText::_('DISPLAY_THE_CART'); $displayAllText = JText::_('DISPLAY_THE_CARTS'); $emptyText = JText::_('CART_EMPTY'); } if(empty($desc) && $desc != '0'){ $this->params->set('msg',$emptyText); } if(!headers_sent()){ header( 'Cache-Control: no-store, no-cache, must-revalidate' ); header( 'Cache-Control: post-check=0, pre-check=0', false ); header( 'Pragma: no-cache' ); } $cart_type=$this->params->get('cart_type','cart'); if($this->params->get('from','no') == 'no'){ $this->params->set('from',JRequest::getString('from','display')); } if(empty($this->rows)){ $desc = trim($this->params->get('msg')); if(!empty($desc) || $desc == '0'){ echo $this->notice_html; ?> <div id="hikashop_cart" class="hikashop_cart"> <?php echo $desc; ?> </div> <div class="clear_both"></div> <?php } }else{ ?> <div id="hikashop_cart" class="hikashop_cart"> <?php if($this->config->get('print_cart',0) && JRequest::getVar('tmpl','')!='component' && $cart_type != 'wishlist'){ ?> <div class="hikashop_checkout_cart_print_link"> <a title="<?php echo JText::_('HIKA_PRINT');?>" class="modal" rel="{handler: 'iframe', size: {x: 760, y: 480}}" href="<?php echo hikashop_completeLink('checkout&task=printcart',true); ?>"> <img src="<?php echo HIKASHOP_IMAGES; ?>print.png" alt="<?php echo JText::_('HIKA_PRINT');?>"/> </a> </div> <?php } else if($this->params->get('from','display') != 'module'){ echo '<div class="hikashop_product_cart_links">'; echo '<div class="hikashop_product_cart_show_carts_link">'; echo $this->cart->displayButton($displayAllText,'cart',$this->params,hikashop_completeLink('cart&task=showcarts&cart_type='.$cart_type.$url_itemid),''); echo '</div>'; ?> <div class="hikashop_product_cart_mail_link"> <a title="<?php echo JText::_('HIKA_EMAIL');?>" class="modal" rel="{handler: 'iframe', size: {x: 760, y: 480}}" href="<?php echo hikashop_completeLink('product&task=sendcart',true); ?>"> <img src="<?php echo HIKASHOP_IMAGES; ?>go.png" alt="<?php echo JText::_('HIKA_EMAIL');?>"/> </a> </div> <div class="hikashop_product_cart_print_link"> <a title="<?php echo JText::_('HIKA_PRINT');?>" class="modal" rel="{handler: 'iframe', size: {x: 760, y: 480}}" href="<?php echo hikashop_completeLink('product&task=printcart',true); ?>"> <img src="<?php echo HIKASHOP_IMAGES; ?>print.png" alt="<?php echo JText::_('HIKA_PRINT');?>"/> </a> </div> <?php echo '</div><div class="clear_both"></div>'; } echo $this->notice_html; $row_count = 1; if($this->params->get('small_cart')){ $this->row=$this->total; if($this->params->get('show_cart_quantity',1)){ $qty = 0; $group = $this->config->get('group_options',0); foreach($this->rows as $i => $row){ if(empty($row->cart_product_quantity) && $cart_type != 'wishlist') continue; if($group && $row->cart_product_option_parent_id) continue; $qty+=$row->cart_product_quantity; } $text = JText::sprintf('X_ITEMS_FOR_X',$qty,$this->loadTemplate()); }else{ $text = JText::sprintf('TOTAL_IN_CART_X',$this->loadTemplate()); } if($cart_type != 'wishlist'){ ?> <a class="hikashop_small_cart_checkout_link" href="<?php echo hikashop_completeLink('checkout'.$url_itemid); ?>"> <span class="hikashop_small_cart_total_title"><?php echo $text; ?></span> </a><?php if($this->params->get('show_cart_delete',1)){ $delete = hikashop_completeLink('product&task=cleancart'); if(strpos($delete,'?')){ $delete.='&amp;'; }else{ $delete.='?'; } ?> <a class="hikashop_small_cart_clean_link" href="<?php echo $delete.'return_url='. urlencode(base64_encode(hikashop_currentURL('url',false))); ?>" > <img src="<?php echo HIKASHOP_IMAGES . 'delete2.png';?>" border="0" alt="clean cart" /> </a><?php } if($this->params->get('show_cart_proceed',1) && $this->params->get('cart_type','cart') != 'wishlist' && $this->params->get('from','display') == 'module'){ echo $this->cart->displayButton(JText::_('PROCEED_TO_CHECKOUT'),'checkout',$this->params,hikashop_completeLink('checkout'.$url_itemid),'window.location=\''.hikashop_completeLink('checkout'.$url_itemid).'\';return false;'); } }else{ foreach($this->rows as $row){ $cart_id = $row->cart_id; } ?> <a class="hikashop_small_cart_checkout_link" href="<?php echo hikashop_completeLink('cart&task=showcart&cart_id='.$cart_id.'&cart_type='.$cart_type.$url_itemid); ?>"> <span class="hikashop_small_cart_total_title"><?php echo $text; ?></span> </a> <?php } }else{ if($cart_type == 'wishlist'){ $form = 'hikashop_wishlist_form'; } else{ $form = 'hikashop_cart_form'; } ?> <form action="<?php echo hikashop_completeLink('product&task=updatecart'.$url_itemid,false,true); ?>" method="post" name="<?php echo $form;?>"> <table width="100%"> <thead> <tr> <?php if(@$this->params->get('image_in_cart')){ ?> <th class="hikashop_cart_module_product_image_title hikashop_cart_title"> <?php echo JText::_('CART_PRODUCT_IMAGE'); ?> </th> <?php } ?> <th class="hikashop_cart_module_product_name_title hikashop_cart_title"> <?php echo JText::_('CART_PRODUCT_NAME'); ?> </th> <?php if($this->params->get('show_cart_quantity',1)){ $row_count++; ?> <th class="hikashop_cart_module_product_quantity_title hikashop_cart_title"> <?php echo JText::_('CART_PRODUCT_QUANTITY'); ?> </th> <?php } if($this->params->get('show_price',1)){ $row_count++; ?> <th class="hikashop_cart_module_product_price_title hikashop_cart_title"> <?php echo JText::_('CART_PRODUCT_PRICE'); ?> </th> <?php } if($this->params->get('show_cart_delete',1)){ $row_count++; ?> <th class="hikashop_cart_title"> </th> <?php } if($row_count<2){ ?> <th></th> <?php }?> </tr> </thead> <?php if($this->params->get('show_price',1) && $this->params->get('cart_type','cart') != 'wishlist'){ ?> <tfoot> <tr> <td colspan="<?php echo $row_count;?>"> <hr /> </td> </tr> <tr> <?php $colspan = '1'; if($this->params->get('show_cart_quantity',1)){ $colspan=2; } ?> <td class="hikashop_cart_module_product_total_title" colspan="<?php echo $colspan; ?>"> <?php echo JText::_('HIKASHOP_TOTAL'); ?> </td> <td class="hikashop_cart_module_product_total_value"> <?php $this->row=$this->total; echo $this->loadTemplate(); ?> </td> <?php if($this->params->get('show_cart_delete',1)){ ?> <td> </td> <?php }?> <?php if($row_count<2){ ?> <td> </td> <?php }?> </tr> </tfoot> <?php } ?> <tbody> <?php $k = 0; $this->cart_product_price = true; $group = $this->config->get('group_options',0); $cart_id = 0; $app = JFactory::getApplication(); $productClass = hikashop_get('class.product'); $defaultParams = $this->config->get('default_params'); $this->image = hikashop_get('helper.image'); $height = $this->config->get('thumbnail_y'); $width = $this->config->get('thumbnail_x'); foreach($this->rows as $i => $row){ $cart_id = $row->cart_id; if(empty($row->cart_product_quantity)&& $cart_type != 'wishlist' || @$row->hide == 1) continue; if($group && $row->cart_product_option_parent_id) continue; $productClass->addAlias($row); ?> <tr class="<?php echo "row$k"; ?>"> <?php if(@$this->params->get('image_in_cart')){ ?> <td class="hikashop_cart_module_product_image hikashop_cart_value" style="vertical-align:middle !important; text-align:center;"> <?php echo $this->image->display(@$row->images[0]->file_path,true,@$row->images[0]->file_name,'id="hikashop_main_image_'.$row->product_id.'" style="margin-top:10px;margin-bottom:10px;display:inline-block;vertical-align:middle"','', $width, $height); ?> </td> <?php } ?> <td class="hikashop_cart_module_product_name_value hikashop_cart_value"> <?php if(@$defaultParams['link_to_product_page']){ ?> <a href="<?php echo hikashop_completeLink('product&task=show&cid='.$row->product_id.'&name='.$row->alias.$url_itemid);?>" ><?php } ?> <?php echo $row->product_name; ?> <?php if ($this->config->get('show_code')) { ?> <span class="hikashop_product_code_cart"><?php echo $row->product_code; ?></span> <?php } ?> <?php if(@$defaultParams['link_to_product_page']){ ?></a><?php } ?> <p class="hikashop_cart_product_custom_item_fields"> <?php if(hikashop_level(2) && !empty($this->itemFields)){ foreach($this->itemFields as $field){ $namekey = $field->field_namekey; if(!empty($row->$namekey) && !strlen($row->$namekey)){ echo '<p class="hikashop_cart_item_'.$namekey.'">'.$this->fieldsClass->getFieldName($field).': '.$this->fieldsClass->show($field,$row->$namekey).'</p>'; } } } $input=''; if($group){ foreach($this->rows as $j => $optionElement){ if($optionElement->cart_product_option_parent_id != $row->cart_product_id) continue; if(!empty($optionElement->prices[0])){ if(!isset($row->prices[0])){ $row->prices[0]->price_value=0; $row->prices[0]->price_value_with_tax=0; $row->prices[0]->price_currency_id = hikashop_getCurrency(); } foreach(get_object_vars($row->prices[0]) as $key => $value){ if(is_object($value)){ foreach(get_object_vars($value) as $key2 => $var2){ if(strpos($key2,'price_value')!==false) $row->prices[0]->$key->$key2 +=@$optionElement->prices[0]->$key->$key2; } }else{ if(strpos($key,'price_value')!==false) $row->prices[0]->$key+=@$optionElement->prices[0]->$key; } } } ?> <p class="hikashop_cart_option_name"> <?php echo $optionElement->product_name; ?> </p> <?php $input .='document.getElementById(\'cart_product_option_'.$optionElement->cart_product_id.'\').value=qty_field.value;'; echo '<input type="hidden" id="cart_product_option_'.$optionElement->cart_product_id.'" name="item['.$optionElement->cart_product_id.'][cart_product_quantity]" value="'.$row->cart_product_quantity.'"/>'; } } ?> </p> </td> <?php if($this->params->get('show_cart_quantity',1)){ ?> <td class="hikashop_cart_module_product_quantity_value hikashop_cart_value"> <?php if(empty($session)) $session = new stdClass(); $session->cart_id = $app->getUserState( HIKASHOP_COMPONENT.'.'.$cart_type.'_id', 0, 'int' ); if($row->cart_id == $session->cart_id && $this->params->get('from','display') != 'module'){ ?> <input id="hikashop_wishlist_quantity_<?php echo $row->cart_product_id;?>" type="text" name="item[<?php echo $row->cart_product_id;?>][cart_product_quantity]" class="hikashop_product_quantity_field" value="<?php echo $row->cart_product_quantity; ?>" onchange="var qty_field = document.getElementById('hikashop_wishlist_quantity_<?php echo $row->cart_product_id;?>'); if (qty_field){<?php echo $input; ?> } document.<?php echo $form; ?>.submit(); return false;" /> <div class="hikashop_cart_product_quantity_refresh"> <a href="#" onclick="var qty_field = document.getElementById('hikashop_cart_quantity_<?php echo $row->cart_product_id;?>'); if (qty_field && qty_field.value != '<?php echo $row->cart_product_quantity; ?>'){<?php echo $input; ?> qty_field.form.submit(); } return false;" title="<?php echo JText::_('HIKA_REFRESH'); ?>"> <img src="<?php echo HIKASHOP_IMAGES . 'refresh.png';?>" border="0" alt="<?php echo JText::_('HIKA_REFRESH'); ?>" /> </a> </div> <?php }else{ ?> <input id="hikashop_cart_quantity_<?php echo $row->cart_product_id;?>" type="text" name="item[<?php echo $row->cart_product_id;?>][cart_product_quantity]" class="hikashop_product_quantity_field" value="<?php echo $row->cart_product_quantity; ?>" onchange="var qty_field = document.getElementById('hikashop_cart_quantity_<?php echo $row->cart_product_id;?>'); if (qty_field){<?php echo $input; ?> } document.<?php echo $form; ?>.submit(); return false;" /> <?php } if($this->params->get('show_delete',1) && $this->params->get('from','display') != 'module'){ ?> <div class="hikashop_cart_product_quantity_delete"> <a href="<?php echo hikashop_completeLink('product&task=updatecart&product_id='.$row->product_id.'&quantity=0&return_url='.urlencode(base64_encode(hikashop_currentURL('return_url')))); ?>" onclick="var qty_field = document.getElementById('hikashop_checkout_quantity_<?php echo $row->cart_product_id;?>'); if(qty_field){qty_field.value=0; <?php echo $input; ?> qty_field.form.submit();} return false;" title="<?php echo JText::_('HIKA_DELETE'); ?>"> <img src="<?php echo HIKASHOP_IMAGES . 'delete2.png';?>" border="0" alt="<?php echo JText::_('HIKA_DELETE'); ?>" /> </a> </div> <?php } ?> </td> <?php } if($this->params->get('show_price',1)){ ?> <td class="hikashop_cart_module_product_price_value hikashop_cart_value"> <?php $this->row=&$row; echo $this->loadTemplate(); ?> </td> <?php } if($this->params->get('show_cart_delete',1) && $this->params->get('cart_type','cart') != 'wishlist'){ ?> <td class="hikashop_cart_module_product_delete_value hikashop_cart_value"> <a href="<?php echo hikashop_completeLink('product&task=updatecart&cart_product_id='.$row->cart_product_id.'&quantity=0&return_url='.urlencode(base64_encode(urldecode($this->params->get('url'))))); ?>" onclick="var qty_field = document.getElementById('hikashop_cart_quantity_<?php echo $row->cart_product_id;?>'); if(qty_field){qty_field.value=0;<?php echo $input; ?> document.hikashop_cart_form.submit(); return false;}else{ return true;}" title="<?php echo JText::_('HIKA_DELETE'); ?>"><img src="<?php echo HIKASHOP_IMAGES . 'delete2.png';?>" border="0" alt="<?php echo JText::_('HIKA_DELETE'); ?>" /></a> </td> <?php } if($cart_type == 'wishlist' && $this->params->get('from','display') != 'module'){ ?> <td class="hikashop_wishlist_display_add_to_cart"> <!-- Add 'ADD_TO_CART' button --> <?php $form = ',\'hikashop_wishlist_form\''; $this->ajax = ' if(qty_field == null){ var qty_field = document.getElementById(\'hikashop_wishlist_quantity_'.$row->cart_product_id.'\').value; } if(hikashopCheckChangeForm(\'item\',\'hikashop_wishlist_form\')){ return hikashopModifyQuantity(\'' . $this->row->product_id . '\',qty_field,1,\'hikashop_wishlist_form\',\'cart\'); } else { return false; } '; $this->setLayout('quantity'); echo $this->loadTemplate(); $this->setLayout('listing_price'); ?> </td> <?php } if($row_count<2){ ?> <td></td> <?php }?> </tr> <?php $k = 1-$k; } $this->cart_product_price=false; ?> </tbody> </table> <?php if($this->params->get('show_cart_quantity',1)){ ?> <noscript> <input type="submit" class="btn button" name="refresh" value="<?php echo JText::_('REFRESH_CART');?>"/> </noscript> <?php } if($this->params->get('cart_type','cart') != 'wishlist' && $this->params->get('from','display') == 'module'){ if($this->params->get('show_cart_proceed',1)) echo $this->cart->displayButton(JText::_('PROCEED_TO_CHECKOUT'),'checkout',$this->params,hikashop_completeLink('checkout'.$url_itemid),''); } else{ ?><div class="hikashop_display_cart_show_convert_button"><?php $cart_type = '&cart_type='.$this->params->get('cart_type','cart'); if($this->params->get('from','display') != 'module'){ echo $this->cart->displayButton($convertText,'wishlist',$this->params,hikashop_completeLink('cart&task=convert'.$url_itemid.$cart_type),'window.location.href = \''.hikashop_completeLink('cart&task=convert'.$url_itemid.$cart_type).'\';return false;'); } else{ echo $this->cart->displayButton($displayText,'wishlist',$this->params,hikashop_completeLink('cart&task=showcart&cart_id='.$cart_id.$url_itemid.$cart_type),'window.location.href = \''.hikashop_completeLink('cart&task=showcart&cart_id='.$cart_id.$url_itemid.$cart_type).'\';return false;'); } ?></div><?php } ?> <input type="hidden" name="url" value="<?php echo $this->params->get('url');?>"/> <input type="hidden" name="ctrl" value="product"/> <input type="hidden" name="task" value="updatecart"/> </form> <?php } ?> </div> <div class="clear_both"></div> <?php } ?> <?php if(JRequest::getWord('tmpl','')=='component'){ if(!headers_sent()){ header('Content-Type: text/css; charset=utf-8'); } exit; }
Last edit: 12 years 7 months ago by george1988.
12 years 7 months ago - 12 years 7 months ago #146464 by george1988
well, I still cant figure out why it not working as it should by default maybe is the T3 template or something...
but i fixed it and now it works just as i needed.
added to my custom css file the code below to remove the links when printing.
@media print { .noprint {display:none !important;} a:link:after, a:visited:after { display: none; content: ""; } }
and added this at top of product / cart.php not sure if wrote it correctly but it works.
<a <?php echo JText::_('HIKA_PRINT');?>" rel="{handler: 'iframe', size: {x: 760, y: 480}}" href="<?php echo hikashop_completeLink('checkout&task=printcart',true); ?>" target="_blank"><img src="<?php echo HIKASHOP_IMAGES; ?>print.png" alt="<?php echo JText::_('HIKA_PRINT');?>"/>
Time to create page: 0.403 seconds
