HikaShop Content Module not appearing
12 years 7 months ago #145339 by optimized
-- url of the page with the problem -- : optimizedpanama.com/starsupply/
-- Joomla version -- : 3.2.1
-- PHP version -- : x5.4
-- Browser(s) name and version -- : All
I have set HikaShop Content Module to be in module position bottom 4 (which works) but it will not appear
I have read the documentation but still van not make it display
Mike
12 years 7 months ago #145407 by nicolas
It's probably that you configured the module options in a way that doesn't display any product/category.
Could you provide a screenshot of the Hikashop options of your module (via the menu Display->Content modules) ?
12 years 7 months ago #145411 by optimized
Please find screenshots attached
Mike
12 years 7 months ago #145425 by nicolas
There is nothing attached to your message.
12 years 7 months ago #145436 by optimized
Here we go
12 years 7 months ago #145437 by optimized
Here we go
12 years 7 months ago #145451 by nicolas
There is still no screenshot attached to your message. Maybe you could upload it on your website and provide a link to it ?
12 years 7 months ago #145460 by optimized
12 years 7 months ago #145462 by nicolas
The module is not configured properly as far as I can see.
First, the synchronize with currently displayed item when possible option should be turned off, otherwise, you might not see anything based on your page you are on.
Then, in the associated category option, you should select the main category where your categories that you want to display in the module and not select one of them.
Finally, the sub element filter option should be set to either direct sub elements or all sub elements.
12 years 7 months ago #145466 by optimized
Hello Nicolas,
I really appreciate your help on this. Is there a use guide that I can refer to so that I do not have to bother you so much?
Mike
12 years 7 months ago #145470 by nicolas
On each page, you can click on the help button and that will give you the help related to the current screen.
Also, you can find the full manual of HikaShop here:
www.hikashop.com/support/documentation.html
12 years 7 months ago #145609 by optimized
Thanks,
Are there 'latest products', 'most popular products' modules that I can download?
Mike
12 years 7 months ago #145659 by Eliot
Hi Mike,
You don't have to download these modules. It's included when you install Hikashop and you just have to enable them or configure a new one that fits your need.
Time to create page: 0.344 seconds
