Product listing not appearing
- cognoscitiva
12 years 8 months ago #145758
by cognoscitiva
Product listing not appearing was created by cognoscitiva
cognoscitiva-es.com/shop/index.php?optio...egulares-&Itemid=250
HikaShop version -- : updated in Sep 2013
Joomla version -- : Version 1.5.22
We are having a situation with the products associeted with a category that appear when you click in the left navigator bar of the site, but when you click in the same but in the area where the products and sub-categories appear, the same category is not listing the produts.
The main category is this one (for exemple):
cognoscitiva-es.com/shop/index.php?optio...t=listing&Itemid=250
and if you click in the sub-category on the left bar, you see the products listing
cognoscitiva-es.com/shop/index.php?optio...t=listing&Itemid=153
but if you navigate on the main area sub-categories, it's empty with no products
we already try to create new sub-categories in the "Menus »»» Menu Shop" and associate with the ones created on hikashop, but it appends the same to the new ones.
have any idea how can this bug be resolved?
Thanks a lot in advanced!!!
Cheers
Cheers
12 years 8 months ago #145855
by Xavier
Replied by Xavier on topic Product listing not appearing
In the options of the categories listing module, thanks to select a category listing menu for the "menu" option.
Then, edit the selected menu options, and in its options, select a products listing associated module.
- cognoscitiva
12 years 8 months ago #145904
by cognoscitiva
is that in module manager of joomla? there's a numbered list of "Associated products listing for category listing menu", but all of them unpublished.
Replied by cognoscitiva on topic Product listing not appearing
12 years 8 months ago #145907
by Xavier
No it's in HikaShop > Display > Content modules, edit the categories listing modules that you have configured.
And you should see the option on the left side at the bottom.
The following user(s) said Thank You: cognoscitiva
- cognoscitiva
12 years 8 months ago #145931
by cognoscitiva
in the Content modules of HikaShop there only the same kind of list with numbered "Associated products listing for category listing menu", but all of them unpublished. And in the end of the list there's the latest products, related products and hikashop cart module.
We tried to use the same kind of options configuration, of another category that is working properly, in (Display »»» content menus) and also in the "joomla menu options" that are associated with each category and sub-category, but still it's not working.
- cognoscitiva
12 years 8 months ago #145961
by cognoscitiva
12 years 8 months ago #146279
by Xavier
I just tried again you website and it seems to be working fine now
- cognoscitiva
12 years 7 months ago #149723
by cognoscitiva
indeed it did ! it was strange 'cause all the changes were done a day before that.
thanks a lot for your reply!
Time to create page: 0.115 seconds
