products are shown double on my product-listings
12 years 8 months ago - 12 years 8 months ago #147625 by renew
-- Joomla version -- : 3.1.5
-- URL: goo.gl/TZADxc
do you know, why my products are shown double on my product-listings page?
there is a second listing at the bottom of the page?
THANK YOU
Last edit: 12 years 8 months ago by renew.
12 years 8 months ago #147632 by Mohamed Thelji
That's probably coming from the fact that you are showing a product listing content menu and module which are displaying the same products through your page.
Can you give me a link to your page so that I can have more information about your issue ?
12 years 8 months ago #147739 by renew
12 years 8 months ago #147752 by Mohamed Thelji
You should :
- Remove the associated module of the "associated modules" option of your Hikashop content menu which have the ID number 289 ("Hikashop->Display->Content menus")
- Delete the associated module which have the ID number 135 through "Hikashop->Display->Content modules"
10 years 2 months ago #249363 by mschnyde
I have the same problem, but really don't know why. Even I cannot follow your instruction
could you help me on that www.bluegun.ch
Kind regards,
Marco
10 years 2 months ago #249369 by nicolas
On your website, it seems to be coming from some customization that was done to one of the views of HikaShop. Hard to say what and where. If you try with the default Joomla template, it should display fine.
So you can try renaming the files in templates/YOUR_TEMPLATE/html/com_hikashop/ one by one via FTP to see which one is causing the problem and then seek advice with the person who made the customization (it might be your template provider).
