Compare Products info
12 years 8 months ago #148859 by swhps
Compare Products info was created by swhps
-- HikaShop version -- : 2.3
-- Joomla version -- : 3.2
Where do we go to edit what info is shown when products are compared? At the moment, it is only comparing the pic and weight. It would be useful if the description was shown.
12 years 8 months ago #148883 by nicolas
Replied by nicolas on topic Compare Products info
Usually, you would create custom fields of the table "product" via the menu Display->Custom fields in order for you to fill these fields for each product and then they would appear automatically on the comparison table.
Now if you want to add the description, that will require to edit the file "compare" of the view "product" via the menu Display->Views in order to add custom code similar to the code you can see there for the product name in order to display the description.
The following user(s) said Thank You: swhps
